upTOP Overland Racks and Accessories - NOW WITH FREE SHIPPING (CONUS ONLY)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by upTOPOverland_Drew, Mar 15, 2019.
  1. May 11, 2020 at 8:24 PM
    #2581
    DeusExMachina
    DeusExMachina Well-Known Member
    Denver, CO
    2020 Tacoma 4x4 Sport 6MT access cab
    I married my tacoma likes this.
  2. May 11, 2020 at 10:52 PM
    #2582
    Amanhowzit taco
    Amanhowzit taco Well-Known Member
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    265/75/16 tires only everything else stock.
    Make sure its screwed on super tight and then put the light bar up and if it still has the noise go from there. I just installed mine and had the same thought- metal spacers sitting directly on the frame possibly not a good idea? I don’t know- I tightened mine down more and will test drive tomorrow to see if my noise went away. Nothing is perfect.
    Slamchez25[QUOTED] likes this.
  3. May 11, 2020 at 11:20 PM
    #2583
    upTOPoverland
    upTOPoverland Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    i can almost guarantee this noise is from the lack of light bar. Air is catching the grooves in the first bar and causing the noise. One a bar fills the hole your rack will quiet down. It has nothing to do with the metal spacers.
    do not replace the spacers, plastic or rubber will compress over time. The silicone will do the job of a rubber washer in terms of dampening
  4. May 12, 2020 at 5:59 AM
    #2584
    ExploreBackcountry
    ExploreBackcountry Oak & Iron Studios
    2019 MGM Tacoma TRD Off-Road
    Thanx. it is a Hammond 1590EBK Aluminum project box
  5. May 12, 2020 at 1:34 PM
    #2585
    Big_Salad
    Big_Salad Well-Known Member
    Mark
    Bay Area
    2019 Cement TRD OR DCLB
    Anyone with an Extreme LED X6S know exactly what the red and white wire coming directly from the bar are? I am assuming that the red wire is power for the center clear lights, and white wire is power for the amber lights, but want to be clear. I'll be wiring these up to the Switchpro, and don't need to worry about switches and relays.
  6. May 12, 2020 at 2:44 PM
    #2586
    TCP802
    TCP802 Well-Known Member
    Westminster, CO
    2017 MGM DCLB OR
    Is there a long bed version of the truss racks? Don't see it as an option on the Web site. Specifically I am looking at the Softopper version
  7. May 12, 2020 at 5:56 PM
    #2587
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    all of our tacoma trusses are the same length at 50”
  8. May 12, 2020 at 5:58 PM
    #2588
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    extreme changes their wiring once a month it seems like. White is normally amber, red is normally white. If not, just switch them on the switch pro lol
  9. May 12, 2020 at 6:02 PM
    #2589
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    @Slamchez25 Easy way to test that. Run a strip of gaff tape over the light bar holes and go for a drive. Or several layers of painter/masking tape. Take a drive. Noise gone? Put in a light. But dont leave the tape. The residue will be a PITA to work off.
  10. May 12, 2020 at 8:37 PM
    #2590
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    @upTOPoverland just a thought. Is there any way to further increase the height of the rack? Based on the OG model with the adjustments on the slots being at max height, I feel like the rack may actually be touching the roof. Would you happen to have longer aluminum spacers?
    RubenZ likes this.
  11. May 12, 2020 at 9:50 PM
    #2591
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    Yes, pm me
  12. May 12, 2020 at 10:33 PM
    #2592
    RubenZ
    RubenZ Well-Known Member
    South Texas
    2020 Cement Tacoma TRD Off-Road DCSB
    OG model?
    CttAznRanger[QUOTED] likes this.
  13. May 13, 2020 at 4:32 AM
    #2593
    CttAznRanger
    Brandon
    Boston, MA
    I have the very original Alpha model they made.
  14. May 13, 2020 at 5:03 AM
    #2594
    Gregw138
    Gregw138 Well-Known Member
    Greg
    NY
    2019 TRD Off Road DCSB 2016 Lexus ES350 2009 Lexus ES350
    WAY TOO MANY
  15. May 13, 2020 at 5:09 AM
    #2595
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    :fistbump:
  16. May 13, 2020 at 5:10 AM
    #2596
    uploadadventure
    Dixon, Mo
    Ugh. I wouldn’t want to undo my mounting bolts with the amount of silicone I put on mine. It would be a nightmare.
  17. May 13, 2020 at 5:31 AM
    #2597
    CttAznRanger
    Brandon
    Boston, MA
    While this is true, I have to undo mine because I have yet to put on the weather stripping. Hopefully mine goes better because I used RTV. Hopefully...
  18. May 13, 2020 at 6:40 AM
    #2598
    TCP802
    Westminster, CO
    2017 MGM DCLB OR
    Thanks, any chance you have a any pics with a truss rack on a long bed, little worried it is going to look short with the topper.
  19. May 13, 2020 at 6:51 AM
    #2599
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    brandon bought a rack from us very shortly after we opened our doors, our racks look very different now.
    RubenZ[QUOTED] and CttAznRanger like this.
  20. May 13, 2020 at 6:53 AM
    #2600
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    not a softtopper truss but i can dig up a few of a standard truss on a LB
