upTOP Overland Racks and Accessories - NOW WITH FREE SHIPPING (CONUS ONLY)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by upTOPOverland_Drew, Mar 15, 2019.
  1. May 14, 2020 at 2:37 PM
    #2621
    DeusExMachina
    DeusExMachina Well-Known Member
    Denver, CO
    2020 Tacoma 4x4 Sport 6MT access cab
    I've been dealing with a squeak/creak, turns out I didn't tighten the rack-to-roof bolts enough. Oops. No vibration, no wind noise though.
  2. May 14, 2020 at 3:28 PM
    #2622
    jshields
    jshields Well-Known Member
    2019 SR5 4x4 double cab
    I figured that was probably it. I just want to make sure I didnt screw something up. The high pitch squeal sounds like it around the area between the drivers front and back door. Figured it was the scene pod knock outside that are still in.
  3. May 14, 2020 at 4:53 PM
    #2623
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Nice!! I’m jealous of the bravo. I really like how simple and clean it is. And the ability to access the rack bars on the outside.
  4. May 14, 2020 at 9:06 PM
    #2624
    upTOPoverland
    upTOPoverland Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    the scenePODS probably aren't the issue unless there is a nasty crosswind
    I married my tacoma likes this.
  5. May 15, 2020 at 7:07 AM
    #2625
    jshields
    I was driving into a pretty hard head wind.
    upTOPoverland[QUOTED] likes this.
  6. May 15, 2020 at 9:33 AM
    #2626
    Ravenous_Avarice
    Ravenous_Avarice Member
    NY
    2018 Off Road DCSB
    I'm having a significant whistle with my heretic bar installed. Starts right around 45mph. Any thoughts on how to stop this? I know it's from the cutout as I covered it and drove around and otherwise the rack is silent.
  7. May 15, 2020 at 9:40 AM
    #2627
    RubenZ
    RubenZ Well-Known Member
    South Texas
    2020 Cement Tacoma TRD Off-Road DCSB
    I wonder if you need to redo the Silicon as tightening it more than what you originally had may have broken the seal.
    ORtoCOTaco likes this.
  8. May 15, 2020 at 1:49 PM
    #2628
    MattR820
    MattR820 Active Member
    2011 Double Cab offroad
    It's going to scream like a banshee until you get your lightbar installed. Just tape over the holes until then.
  9. May 15, 2020 at 1:52 PM
    #2629
    MattR820
    Quick hint, even though you have the remote, you do need to wire in the switches, the remote won't work without that circuit completed. I'm not saying you have to take it through the firewall, or anything fancy, it's just got to be there. You could probably make a completed circuit without switches at all just to complete it, but I just used their switches and hid them behind my kick panel.
    RubenZ[QUOTED] likes this.
  10. May 15, 2020 at 2:01 PM
    #2630
    ProjectBangarang
    ProjectBangarang Well-Known Member
    Utah
    2020 Cement TRD Off-Road
    Total Chaos Bed Stiffeners C4 Bed Bars Smittybilt RTT Uptop Overland Bravo
    Is it possible to get the inner plate as the accent color instead of the outer (Like the way it is in the picture of Meso's truck)? I've seen it this way on a few others but don't see that option on the site.
  11. May 15, 2020 at 4:06 PM
    #2631
    NonTraditional
    NonTraditional Well-Known Member
    DMV
    2016 Tacoma TRD OR DCSB
    At checkout put in the notes you would prefer the inner gooveTEK to be colored and we will get it done!
  12. May 15, 2020 at 4:10 PM
    #2632
    NonTraditional
    DMV
    Wondering if it is the angle of the light bar, have you tried adjusting it?
  13. May 15, 2020 at 5:11 PM
    #2633
    Ravenous_Avarice
    NY
    2018 Off Road DCSB
    Yeah I've been messing around with it quite a bit. They only thing I've found that stopped it was I put tape over the bottom part of the cutout so its now just a straight line. My best guess is the cutout for the heretic bar is acting like a harmonica or something (only because that's what it sounds like). I'll keep messing around with it because I seriously love the look but any input would be appreciated.
  14. May 15, 2020 at 7:37 PM
    #2634
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    yep, put it in the notes when ordering, still make sure you add color match to cart
  15. May 16, 2020 at 4:58 AM
    #2635
    PitCh0w
    PitCh0w Well-Known Member
    Derek
    Boston, MA
    2020 TRD Pro - Army Green
    After months of lurking this thread, I finally pulled the trigger last night on an Alpha rack!
    Got a 30 inch baja designs light bar, four rock lights & scene pods, wiring harness. (and a free awning mount!)
    Also chose the army green outer fairings to color match my 2020. :yay:
    In the meantime, I've got a few things to figure out...
    Looks like I'll have to drill through the roof and push the wires through with a waterproof grommet, as the thin fin is not compatible with the 2020s. If anyone has done this, could you elaborate on where on the roof you drilled? Pics would be greatly appreciated!
    I'm also curious about how to run the wires (from the drilled hole in roof) all the way to a SwitchPro. (I'm considering getting a SwitchPro + mount left of the steering wheel, and above the existing OEM switches.)
    Any insight is much appreciated!
  16. May 16, 2020 at 11:32 AM
    #2636
    joechef
    joechef Well-Known Member
    Joe
    Seattle, WA
    I drilled the hole to pass the wires through on my truck. I’d recommend dropping down the headliner on the inside so you can see where is best to drill. Near the antenna there weren’t any wires so I drilled the hole a few inches to the drivers of it. You can then run the wires above the headliner, on the inside of the airbag and down the a pillar. It will be a tad annoying to pass the harness through the firewall since you already have the switch pros coming back in but that’s probably the cleanest way to go. Adding additional water proofing to the grommet was easy as well.
    Not sure what lightbar you have. I have a 40” OnX6 and the volume of wires going through that grommet plug was tight. Gave that opening a serious run for its money.
  17. May 17, 2020 at 12:43 PM
    #2637
    RubenZ
    South Texas
    Awesome. Thanks for that tip.
  18. May 17, 2020 at 1:00 PM
    #2638
    Big_Salad
    Big_Salad Well-Known Member
    Mark
    Bay Area
    2019 Cement TRD OR DCLB
    Man if you have a switchpro, there really is no need to go into the cab at all. I know they recommend it as the cleanest way, but cutting a 2020 just to run wires back outside seems needless. I myself still haven't decided on whether to run down the windshield sides, or down the back...
    Meso's switchpro cubby mount is an extremely clean way to mount the switchpro switches. ONLY issue is that it's hard to see and press some of the switches from the drivers position. If I didn't have a moonroof and all the Off Road switches up there, I'd definitely have mounted it overhead.
    PitCh0w[QUOTED] likes this.
  19. May 17, 2020 at 9:41 PM
    #2639
    keoniboy70
    keoniboy70 Well-Known Member
    Cypress, TX
    2017 Tacoma TRD OffRoad 4x4 DCSB
    17x9 FUEL Nitro 6 wheels with G2 285/70 R17 tires Dobinson struts and coils with Deaver AAL JBA UCAs Warn Semi-Hidden winch mount Smittybilt XRC9.5 RockyHill sliders SprintBooster Pace Edwards Tonneau With Yakima bars and bike carriers TRD Pro grill UpTOP Bravo rack SP-9100 Meso mirror lights and interior mods
    The other option is to mount the SP switch panel in between the sunroof and the off-road switches like this:
    PitCh0w and upTOPoverland like this.
  20. May 17, 2020 at 10:27 PM
    #2640
    Big_Salad
    Mark
    Bay Area
    Damn that is top notch.
    Was that tough? Haven’t messed with the headliner yet.
