upTOP Overland Racks and Accessories - NOW WITH FREE SHIPPING (CONUS ONLY)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by upTOPOverland_Drew, Mar 15, 2019.
  1. Oct 6, 2020 at 7:32 PM
    #3441
    reymataco
    reymataco Well-Known Member
    Denver, CO
    2020 DCLB Off Road Premium in Slowsand
    They are the mounting feet that came with the install kit from UpTop. In that first picture the rack is upside down to get the feet put on. The kit was well labeled (as far as which bag goes to what) but some of the parts inside each bag didn't quite match the instructions. Maybe this is a new revision of the mounts? SnugTop Rebel with Yakima tracks.
    TinyTech626[QUOTED] likes this.
  2. Oct 6, 2020 at 7:33 PM
    #3442
    reymataco
    Denver, CO
    We have rear rack lights... grab handles go on tomorrow to finish it off.
    EDIT: Grab handles added - all done!
    Jessrin, BOMBS and TinyTech626 like this.
  3. Oct 6, 2020 at 7:36 PM
    #3443
    TinyTech626
    TinyTech626 reverses st. signs & steals everyone's left shoe
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    Oh snap! I didn’t even realize those were the “feet” of the rack. Maaan I’m an idiot some days. I see it now you had it flipped before putting it on the cap. Interesting though! Thanks man!
  4. Oct 7, 2020 at 7:43 AM
    #3444
    fishing4boulders
    fishing4boulders Well-Known Member
    AL
    2020 OR Tacoma 4x4
    I’ll try this again since I used the wrong name last time and this sub moves fast!
    @upTOPoverland could you provide any info on the differences between the alpha rack and pairing the bravo rack with the AAP?
  5. Oct 7, 2020 at 8:03 AM
    #3445
    Da_TAKOma
    Da_TAKOma Well-Known Member
    Bay Area
    2020 TRD Pro Army Green
    Bone stock as of now.
    Also, @upTOPoverland could you also show the difference of the open air vs non open air selection???
  6. Oct 7, 2020 at 9:43 AM
    #3446
    upTOPoverland
    upTOPoverland Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
  7. Oct 7, 2020 at 9:44 AM
    #3447
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    I don't have pics of fresh air vs non fresh air. all fresh air is two smaller bars that go around sunroof to effectively 'box' it. Fresh air replaces one load bar.
    Da_TAKOma[QUOTED] likes this.
  8. Oct 7, 2020 at 10:21 AM
    #3448
    Justin_Exploring
    Justin_Exploring Well-Known Member
    2019 BRM Tacoma TRD OR DCSB 4x4
    That doesn't really explain it though. I'm considering the Bravo now and then adding the AAP later down the road. Will that give me the 1/2" wire channel that the alpha has? Other than that is the only difference between the Alpha and Bravo the 7th load bar and stainless hardware vs black oxide?
  9. Oct 7, 2020 at 10:26 AM
    #3449
    fishing4boulders
    AL
    2020 OR Tacoma 4x4
    @upTOPoverland thanks for posting the video to show the differences between the alpha and bravo. My question goes just one step further in trying to understand the difference between the alpha versus getting a bravo rack and adding the aap. Seems like about a $100 difference and I was curious if it may be worth it to upgrade to an alpha vs saving money and going with the combination.
    thanks again for taking the time to answer these questions
    Justin_Exploring likes this.
  10. Oct 7, 2020 at 12:41 PM
    #3450
    NonTraditional
    NonTraditional Well-Known Member
    DMV
    2016 Tacoma TRD OR DCSB
    The main difference as you noted is the initial cost. The Bravo series is priced much lower than the Alpha. Allowing you to get a roof rack, mount your gear, and modify the rack to your liking.
    Bravo without AAp has integrated armorTEK and gooveTEK. This is all a single rail system, does not come with grab handles.
    Alpha has a dual rail system with armorTEK and gooveTEK. Comes with grab handles, and can be color matched.
    $100 price difference is based on the material used. The Bravo AAp and Bravo are made only of 3/16" aluminum compared to the Alpha with an inner grooveTEK rail that is 1/4" aluminum with a 3/16" armorTEK rail.
    This will make the Alpha stronger with the thicker material. It's also the full complete package at once.
    Hope this helps with your decision, either way you can't go wrong with an upTOP overland rack.
  11. Oct 7, 2020 at 12:49 PM
    #3451
    NonTraditional
    DMV
    We only provide and sell stainless steel hardware due to the durability and rust resistance.
  12. Oct 7, 2020 at 1:05 PM
    #3452
    Pyrotech
    Pyrotech Well-Known Member
    Well....
    Part 2 of my little experiment to create something I want/need that I can not find off the shelf.
    RGBW lights for the roof rack.
    I of course love the look of scenePODS @MESO designed, but since they take the Baja Design Rock lights, and they come in single colors only. it simply does not meet all of my needs. :annoyed:
    So, not being one to give up to easy, I went and did some looking around for some RGB rock lights. I found a cheap Set with decent reviews on Amazon and decided to take a chance. I picked up the new mictuning C2 RGBW set from amazon
    Once they arrived, I confirmed they DO NOT fit the scenePODS (like there was any doubt). I set out to design a mount inspired by the original scenePOD.
    housing front.jpg sceanepod RGBW pod- flat top 2.jpg sceanepod RGBW pod- flat top.jpg
    Running a test part now so I can do a fit test and see how it actually looks. may all be a waste of time who knows... but I am having fun designing this little part
  13. Oct 7, 2020 at 1:53 PM
    #3453
    reymataco
    Denver, CO
    Here is my "Fresh Air" option on my DCLB w/ sunroof. Just remove the load bar that would otherwise go across the top of the sunroof and add some orthogonal bars/brackets around the sunroof instead. Hope this helps.
  14. Oct 7, 2020 at 2:03 PM
    #3454
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Nice! The goal of the ScenePod design was to protrude out a little as possible. That's why the bottom half is "inside" while the top half is poking out. This gives you the maximum amount of angled light with least amount of poke.
  15. Oct 7, 2020 at 2:38 PM
    #3455
    reymataco
    Denver, CO
    Turns out, my dog loves @MESO products as much as I do! :annoyed:
  16. Oct 7, 2020 at 2:41 PM
    #3456
    Pyrotech
    OUCH!
  17. Oct 7, 2020 at 2:45 PM
    #3457
    MESO
    State of Jefferson
    I'm gonna have to have a talk with our dedicated shop product tester for slaking on this one.....
    Landpirate, Jessrin, cubie and 11 others like this.
  18. Oct 8, 2020 at 5:33 AM
    #3458
    murphmobile
    murphmobile Never go FULL BROVERLAND
    Murph
    Charlotte, NC
    2016 White TRD Off-Road 4x4
    UpTop Overland Truss, CBI Prinsu Roof Rack, Morimoto Lights/Fogs, 17' 4Runner TRD Wheels, Camping Gear, Empyre Grille, Work-In-Progress
    hmoobgreen and Want2Believe like this.
  19. Oct 8, 2020 at 7:10 AM
    #3459
    RubenZ
    RubenZ Well-Known Member
    South Texas
    2020 Cement Tacoma TRD Off-Road DCSB
    As I start to mount more items to my Racks my only gripe with the UpTop system is why couldn't they be like everyone else and provide an entry point for mounting bolts like below. NOT MY PIC:
    You limit buyers to having to purchase those little half moon nuts which sucks IMO.
    doublethebass, db6598 and reymataco like this.
  20. Oct 8, 2020 at 8:52 AM
    #3460
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    Sorry to disappoint.
