upTOP Overland Racks and Accessories - NOW WITH FREE SHIPPING (CONUS ONLY)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by upTOPOverland_Drew, Mar 15, 2019.
  1. Oct 18, 2020 at 3:00 PM
    #3521
    Piretti16
    Piretti16 Active Member
    Western MA
    2017 TRD OFFROAD
    Bilstein 6112/5160, SPC UCA, cab mount chop, 285 Cooper Discoverer STmaxx, Bestop softopper
    After a long awaited 14 weeks my Softtop Truss finally arrived! Frank and Drew were both very helpful and responsive to all of my anxious calls over the weeks. Unfortunately the headaches didn't end there.... When starting the build up of the rack I noticed that the pre-drilled holes in the upright legs were not pre-tapped as described by the instructions from the website. Not a huge issue as tapping an aluminum hole is like spreading melted butter on freshly burnt toast. When finally getting to the step of reinstalling my softtop I found that the inner most part of the upright legs wouldn't allow for my topper to fit!! Yes I did order the correct Truss system for over a softtopper. After trying to refit the topper and the rack (and about a 6-pack of beer) I decided to pull out the portable bandsaw to chop some notches in the legs. Much success!! I will say that this rack is very well designed and well built! These speedbumps wont be enough to keep me from ordering the Alpha rack come spring (or maybe winter if lead times are still crazy). Keep up the awesome products @upTOPoverland
    BOMBS, hmoobgreen and Acabsurf like this.
  2. Oct 19, 2020 at 5:03 AM
    #3522
    Want2Believe
    Want2Believe Well-Known Member
    Colorado
    2020 Quicksand MT OR
    that is how I positioned it, driver and passenger must have been old instructions
    donp[QUOTED] likes this.
  3. Oct 20, 2020 at 8:57 AM
    #3523
    SubaruTheTacoma
    SubaruTheTacoma SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    Just heard the scoop!
    They are aiming for Black Friday snork release
  4. Oct 20, 2020 at 12:56 PM
    #3524
    reymataco
    reymataco Well-Known Member
    Denver, CO
    2020 DCLB Off Road Premium in Slowsand
    The Prinsu molle panel for their roof rack, happens to fit perfectly on the "Fresh Air" orthogonal load bars.
    https://caliraisedled.com/products/prinsu-roof-rack-mounted-molle-gear-panel
    I am planning to fit my MaxTrax there and build an acrylic fairing to sit in front of them. The UpTOP MaxTrax mounts don't work between the FreshAir bars over the sunroof for this same mounting position. So I won't really get the benefit of the molle other than just having lots of options of how/where to secure the MaxTrax there.
    EDIT: So the MaxTrax do fit here, but they stick forward over the load bar, so that would not leave room to mount a fairing to the front channel of said load bar, as planned. Still pondering the best layout here.
    BOMBS, CttAznRanger and shiftd like this.
  5. Oct 20, 2020 at 12:59 PM
    #3525
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Does it seem like that load panel would fit nicely on the regularly spaced bars?
  6. Oct 20, 2020 at 1:09 PM
    #3526
    reymataco
    Denver, CO
    There are a few different brands of these same panels on CaliRaised. Find the ones with the best dimensions and I am sure one of them would fit. Not sure how exactly, I think the slot to slot (front to back between two bars) on my racks was around 11.5". So a 12" length panel should fit nicely.
    CttAznRanger[QUOTED] likes this.
  7. Oct 21, 2020 at 12:40 PM
    #3527
    reymataco
    Denver, CO
    @upTOPoverland Apologies if this has been answered... what is the t-nut thread size for these racks? M6?
    upTOPoverland likes this.
  8. Oct 22, 2020 at 6:59 AM
    #3528
    upTOPoverland
    upTOPoverland Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    M6 1.0 thread pitch
    reymataco[QUOTED] likes this.
  9. Oct 22, 2020 at 8:20 AM
    #3529
    PitCh0w
    PitCh0w Well-Known Member
    Derek
    Boston, MA
    2020 TRD Pro - Army Green
    @upTOPoverland Do you happen to know the weight for each: retrax truss and and alpha ex? Thanks in advance.
  10. Oct 22, 2020 at 9:07 AM
    #3530
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    retrax truss is about 45 lbs and the alpha eX is about 55lbs.
    PitCh0w likes this.
  11. Oct 22, 2020 at 12:13 PM
    #3531
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I am looking forward to getting my alpha.. only 6 more weeks!
  12. Oct 23, 2020 at 7:17 AM
    #3532
    Nito
    Nito Well-Known Member
    Portland, OR
    ‘20 Cement Off-road DCLB
    BOMBS and CttAznRanger like this.
  13. Oct 26, 2020 at 12:11 PM
    #3533
    drew539
    drew539 New Member
    Will a Thule Cargo box work on the UpTOp Bravo for the Double cab? What is the clearance from the roof to the cross bar on the rack? Also, what is the average install time for the Bravo?
  14. Oct 26, 2020 at 12:34 PM
    #3534
    Nito
    Portland, OR
    Installed mine this weekend. I centered mine in the bed so i'm assuming that's why my Softopper won't clear the tailgate side cross bar. Your rack seems to be closer to the cab. Looks good! i'll get my pics of mine today hopefully but here's a few i shot last night.
    My bars seem to sit quite higher than yours. Based on instructions it said to install at the highest setting so the softopper clears. If I’m understanding correctly.
    Piretti16[QUOTED] likes this.
  15. Oct 26, 2020 at 6:24 PM
    #3535
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    highest setting is only to flip open and close the softtopper. If you are going to leave it fixed, you can drop it lower
  16. Oct 27, 2020 at 1:15 PM
    #3536
    Nito
    Portland, OR
    Yes. I should've clarified, his rack seems to sit lower than mine. So i was curious if his cleared at that setting. I'll lower mine anyways. I don't plan on dropping my softopper very much anyways. Plus I believe(if haven't tried this yet) i can always disconnect it from the side pins and lower into the cab, then fold it to cab end.
    Really happy this this rack and as always, impressed with the quality of the build. It was a long wait, but understandably so. I'll get some better pictures when i can. Hoping to make it out to the Painted Hills this weekend and that'll be perfect for a small photo op. Thanks uptop!
  17. Oct 27, 2020 at 6:51 PM
    #3537
    Piretti16
    Western MA
    2017 TRD OFFROAD
    Thanks man! I moved as close to the cab as a could because the bed rail channel doesn’t extend far enough back for the Bestop clamps. I wanted to make sure there was enough pressure on the bulb seal. I bought a double bulb 1/2”x 1 5/8” weather seal hoping it’ll be a tighter for than the foam. I don’t have any plans to fold the topper forward, so I dropped the crossbar brackets to the 4th(?) hole on the legs. I may actually drop it even lower but for the mean time the crossbars are level with the bars mounted over the cab.
    Excited to see photos of your setup!
  18. Oct 30, 2020 at 7:13 AM
    #3538
    LOWEREDLIFESTYLE
    LOWEREDLIFESTYLE Well-Known Member
    Orlando, FL
    2019 TRD OFFROAD 4X4 (Super White)
    Stealth Customs, UpTop, Morimoto, Diode Dynamics, Meso Customs, Borla, Rotopax, etc
    Ordered my Bravo on 9/9 and its being delivered Tuesday 11/2 (for those looking for current lead times)
    TinyTech626 and DLS6110 like this.
  19. Oct 30, 2020 at 9:12 AM
    #3539
    Trebeckcu
    Trebeckcu Member
    Tim
    2013 Tacoma Limited
    Camper shell, lower light bar, 4x4
    Ordered mine 9/14. Ive heard the x6s lights are on backorder and not shipping. Keep us posted. Thanks for the update. Thats in the 6-8 week window quoted, nice job catching up Uptop guys.
  20. Oct 30, 2020 at 11:26 AM
    #3540
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    It's not on all orders quite yet based on production runs but we are slowly catching up.
    For those watching, we still have Alphas quite backed up, we know :( BUT we are working 10 hour days 6 days a week to hopefully not let you down
