upTOP Overland Racks and Accessories - NOW WITH FREE SHIPPING (CONUS ONLY)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by upTOPOverland_Drew, Mar 15, 2019.
  1. Aug 27, 2019 at 7:57 AM
    #741
    upTOPOverland_Drew
    upTOPOverland_Drew [OP] upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    you can totally do this, mount the feet and groovetek first, insert bars and finish it up. use a blanket to protect your roof
  2. Aug 27, 2019 at 8:00 AM
    #742
    sdezotell
    sdezotell Well-Known Member
    Scott
    Petaluma CA
    2018 Tacoma TRD OffRoad 4X4
    20% Front Tint, Predator Steps, Bilstein 5100 (set @ 0), OME 887 Springs, 1.5" Pro Comp AAL, Wheelers 3/8” Spacer, Cooper Discoverer S/T Maxx 255/85r16, Pro Comp 16/8 Raven Wheels, Auxbeam F-16 LED Headlights, Morimoto XB Foglights, Cali Raised Ditch Lights, Kicker Tweeters, Rockford Fosgate 6x9 & 6.5 Prime Series, KB Voodoo Bed Rack, upTOP Overland Bravo roof rack, Tacoma_Twins grab handles, Cali Raised Bed Channel Stiffeners, Yakima Skyrise 3 RTT, RotoPax, ARB TREDPRO Recovery Board, WaterPort.
    Perfect! Website doesnt have instructions for Bravo yet. Is that coming soon?
  3. Aug 27, 2019 at 9:03 AM
    #743
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Ok I bought it! Direct email sent. Thanks.
  4. Aug 27, 2019 at 9:56 AM
    #744
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Thanks B!...yes Drew is hooking me up, now that I hooked him up with an order ;-).
    I appreciate your PMs with me (they owe you a finders fee...hint hint)...once my rack's through production and delivered I'll post my experience to my build thread and post here as well. I hope you don't mind I copied much of what you did as your Taco looks absolutely perfect (better than the one on their site)...see you at the next meet up.
    CttAznRanger[QUOTED] likes this.
  5. Aug 27, 2019 at 3:32 PM
    #745
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    I did it solo. What I did was build it on the ground. Then put in a blanket/cardboard covering the entire top of the truck. Then putting it on as best I could.
  6. Aug 27, 2019 at 4:38 PM
    #746
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    See, I told you guys lumber was a prime candidate for Uptop use! Here’s ~1000lbs on my FJ. But it had a full length Gobi and I was only traveling as far as the nearest Lowes. That mess turned into a 4x8 lawnmower shed.
  7. Aug 27, 2019 at 8:41 PM
    #747
    upTOPoverland
    upTOPoverland Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    The actual lace plate for the handle is exactly 6.0" wide. The distance hole to hole for the m8 fasteners is 5.25".
  8. Aug 28, 2019 at 12:06 PM
    #748
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    So how is was the thin fin to install??I'm super nervous about it and have a camping trip planned this weekend actually but my racks aren't on yet.let me ask you this.Do you think it's possible to install the rack first, and leave that one load bar off that hits the shark fin and go back at a later date and then so the thin fin?bc i may have no choice due to time restrictions . @Doozy4212
  9. Aug 28, 2019 at 12:32 PM
    #749
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Yup - this is exactly what I did!
    H3llRid3r likes this.
  10. Aug 28, 2019 at 12:34 PM
    #750
    Mack411
    Nice, so you actually did install the rack first as I said and then the thin fin??Is the thin fin as bad as I am worried it is lol??..:help:
  11. Aug 28, 2019 at 12:37 PM
    #751
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Yep! I built the rack on the ground and then put a blanket on the roof and set it in place. Looking back I would have built it on the truck starting with the mounting feet. Specifically cuz I made a mess with the sealant when setting the rack in place. I left off the rear-most cross bar to clear the shark-fin
    Re-assembly of the interior was the hardest part about the thin-fin. Just getting the tabs and clips seated correctly is a bit tedious so the whole thing took me about 2 hours
    I took off the B and C pillars completely to run the wires along the passenger side floor (I choose passenger since the drivers side was getting crowded with wires).
    Mack411[QUOTED] likes this.
  12. Aug 28, 2019 at 12:40 PM
    #752
    Mack411
    So that's part of what I'm confused about, what wires did you have to run especially to the front?I'm confused as to why/how we cant just change the fin to the flush plate and it connect into the factory wiring harness/connector??
  13. Aug 28, 2019 at 12:50 PM
    #753
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    So - the base of the stock shark fin is reused which is where the AM/FM and XM antennas are. What you need to do with the base is solder a piece of wire to the spot where the "areal" is inside of the stock shark fin to act as the actual antenna.
    The rest of the wires were for additional lights. So if you're not adding any lights then you don't need to run any wires. Just disassemble the B and C pillars enough to drop the headliner to reach an arm in to where the antenna attaches.
  14. Aug 28, 2019 at 12:52 PM
    #754
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    @Doozy4212 sent me a zip file with a whole bunch of pictures for install of the thinFIN - did he send you those too?
    Mack411 likes this.
  15. Aug 28, 2019 at 12:58 PM
    #755
    Mack411
    No but I'm betting that he will once he sees this lol
    remotemedic likes this.
  16. Aug 28, 2019 at 12:59 PM
    #756
    upTOPOverland_Drew
    Drew
    Littleton, CO
    I refuse, but I can send instructions :luvya:
  17. Aug 28, 2019 at 1:00 PM
    #757
    Mack411
    Oh I see!!Yeah I actually do plan to add 8 scene pods total and the front light bar,so I guess it would be a good idea but I dont have any of the lights yet so I cant run the wires obviously.I wish I could pre run some type of wiring but I'll just have to go back in I suppose. It is what it is
  18. Aug 28, 2019 at 1:53 PM
    #758
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    I think the directions actually have you install the 7th bar later. I don’t have my kit yet but I read them a few times, you may need to loosen up some of the nearby.
  19. Aug 28, 2019 at 2:06 PM
    #759
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    I don't have my scene lights installed yet either. All I did was leave about 1 foot of wire out and taped it up to one of the cross bars. So the wire is run out of the thin fin, down the C pillar, and up under neath in to the passenger foot well waiting to be connected.
    I didn't want to drop the headliner and remove the thinfin later on to run wires. This way I can add some wire and then connect up the lights on the outside and then just connect switches/power inside and be all set
    H3llRid3r, Cudgel and Mack411[QUOTED] like this.
  20. Aug 30, 2019 at 8:37 AM
    #760
    sdezotell
    Scott
    Petaluma CA
    Any possible issues with it not being square if I install directly on truck?
