upTOP Overland Racks and Accessories - NOW WITH FREE SHIPPING (CONUS ONLY)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by upTOPOverland_Drew, Mar 15, 2019.
  1. Feb 4, 2020 at 5:42 AM
    #1801
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Yup, and to make things more complicated, I had DSIM make some two way splits so I can control the rock lights and puddle lights from separate switches.
    bcgill[QUOTED] likes this.
  2. Feb 4, 2020 at 6:52 AM
    #1802
    TheTacoAdventurer
    TheTacoAdventurer Well-Known Member
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
    Wiring is still to be done, but it's on the truck finally.
    bcgill, BigGuy, Nito and 3 others like this.
  3. Feb 4, 2020 at 6:56 AM
    #1803
    Gregw138
    Gregw138 Well-Known Member
    Greg
    NY
    2019 TRD Off Road DCSB 2016 Lexus ES350 2009 Lexus ES350
    WAY TOO MANY
    Nice ! :thumbsup:
  4. Feb 4, 2020 at 7:21 AM
    #1804
    Gregw138
    Greg
    NY
    WAY TOO MANY
    The MESO harness should be coming out very shortly. I was informed that they were in same shipment as fuse covers.
    bcgill[QUOTED] and CttAznRanger like this.
  5. Feb 4, 2020 at 8:12 AM
    #1805
    upTOPoverland
    upTOPoverland Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    We can send a quickWIRE but it will have wiring for lights bars and the whole schebang. It may be easier to build your own but we are happy to help out any way possible.
  6. Feb 4, 2020 at 8:13 AM
    #1806
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    You guys have shown us a great amount of support and now our lead times are pushing 3 weeks.
  7. Feb 4, 2020 at 8:13 AM
    #1807
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
  8. Feb 4, 2020 at 8:26 AM
    #1808
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    :sawzall:
    Ok. Different usecase from mine. I tap the factory bed lights to drive a relay for the scene lights. That allows me to use the Off-Door-On dash switch native functionality as well.
    As for a harness, being a two wire I’d be inclined to wire it in place. Good luck. Happy to provide significant unsolicited and likely erroneous information as usual.
    CttAznRanger[QUOTED] likes this.
  9. Feb 4, 2020 at 8:41 AM
    #1809
    Nito
    Nito Well-Known Member
    Portland, OR
    ‘20 Cement Off-road DCLB
    I'm in no rush. Just excited to get it! Happy to support a company that takes pride in their work and the countless comments on here back that. I'd rather you all keep your same high level QC than sacrifice it to get the racks out quicker to us. Keep up the good work!
    NonTraditional likes this.
  10. Feb 4, 2020 at 8:47 AM
    #1810
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    I appreciate the good words. we literally send stuff back to powder if we don't like it.....
  11. Feb 4, 2020 at 9:20 AM
    #1811
    CttAznRanger
    Brandon
    Boston, MA
    Yeah, I that might have to be the way I have to do it.
    upTOPoverland[QUOTED] likes this.
  12. Feb 4, 2020 at 10:20 AM
    #1812
    DeusExMachina
    DeusExMachina Well-Known Member
    Denver, CO
    2020 Tacoma 4x4 Sport 6MT access cab
    Ordered my Access Rack last night, along with a 40" S8 and ScenePods! Can't wait!
    This is a good idea, I might have to step up adding the bed lights to my AC. Where did you tap the trigger for the bed light switch? If you have it set to Door do the scene pods turn on as well?
  13. Feb 4, 2020 at 11:18 AM
    #1813
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    From my thread:
    Scene lights (Meso ScenePods):
    • I mounted rock lights and grooveTEKs after painting (red matches other parts). Very easy, cut out the cut outs in the Armor, set and drill a 9/32nds screw hole for the provided pan head screws and gently but firmly push screw in the grooveTEK in essence self tapping the Armor. I choose to pre-mount the rock-light in the housing but it makes no difference.
      For wiring, I wanted to be able to activate these scene lights [the Rock-lights in the GrooveTEKs] from the cargo lamp switch/door switches, so I tapped into the cargo light cable. You do not need to do the whole headliner removal, just the rear to need to gain access to the Cargo-Lamp cable.
      1. With a small panel removal tool or carefully with a small flat head, pop off the hanger hook lower cap, then pinch off the hook clip and remove the rear hanger hooks. This gives you enough headliner slack to access and locate the split tube conduit leading to the cargo light.
      2. Carefully trim the two tape mounts and release to expose.
      3. Tap the: Green (+)-Cargo-Lamp) and White/Purple (-), - ignore the Purple (+Brake) to drive your relay. I fished my lines down the driver's C-Pillar to my wiring junction (relay/power) connections that lead to the power side of the scene lights. More on that elsewhere in my build.
    If the Cargo Switch is "Door" they illuminate with the Door, if it is "On" they are on, and OFF=Off.
    PitCh0w, bcgill, TacoJetMech and 2 others like this.
  14. Feb 4, 2020 at 11:28 AM
    #1814
    TheTacoAdventurer
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
    Hmmmm... this is a tempting solution. I'm not sure which I prefer right now, this or just wiring the pods directly to my switchPro. This would save a switchPro slot (that I'd obviously then have to find a use for) and add functionality with the doors.
  15. Feb 4, 2020 at 1:01 PM
    #1815
    MattR820
    MattR820 Active Member
    2011 Double Cab offroad
    Hi Drew, this is confusing me throughout reading the threads, It the Alpha "the Alpha", or is it "the Alpha xL"? Seems like it used to be the Alpha (Short) and Alpha xL (Long) but I think there's just one Alpha now. Am I guessing right here?
    Thanks.
    The Racks:
    TACOMA:
    • The Alpha xL 2005+: $1299
      • Our flagship solution for the northern most part of your rig! Longer, wider, and more bars. The load out variations are endless with this. Roof Top Tents? We got you. Pelican cases? Yep. Jacks, traction boards, fuel cans? Sheets of wood from the hardware store? Our 50.00" (1270mm) inside width says, you guessed it, even more yep! With an overall length of 65”, 7 load bars, all aluminum construction, reinforced brackets, 316 Stainless hardware kit, and black wrinkle finish powder coating on the load bars, cargo sides, brackets, GPCA handles, and spacers.
  16. Feb 4, 2020 at 1:05 PM
    #1816
    DeusExMachina
    Denver, CO
    Awesome, thanks. I wonder if I have that wire because I have an AC. Looks like a great solution if I want to save a switch. Seems appropriate to have it on the cargo lights.
  17. Feb 4, 2020 at 1:12 PM
    #1817
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    It is just the alpha now! i can update that!
  18. Feb 4, 2020 at 1:13 PM
    #1818
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    The xL is now just the alpha
  19. Feb 4, 2020 at 1:17 PM
    #1819
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    xLlent products
    BOMBS likes this.
  20. Feb 4, 2020 at 1:22 PM
    #1820
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    :rofl::rofl::rofl:
