URD 02 simulator.
Discussion in 'Performance and Tuning' started by n315on, Mar 28, 2011.
  1. Mar 28, 2011 at 12:57 PM
    n315on
    n315on [OP] Well-Known Member
    MA
    02 4x4 SR5
    3'' toytec lift springs wrapped around 5100's. Deck plate mod. TRD seat belt pads. JL audio amps /subs and Alpine speakers. Diff breather mod. Working on a custom rear bumper
    2002 Tacoma 3.4l v6 auto
    Problem:PO420 CEL code is on in my truck, I've tried replacing both o2 sensors and this only temporarily fixes my problem. So now I'm assuming that the problem has to be one of the CATS.
    Question: Could I delete both Cats and run the rear URD o2 sensor simulator without triggering my Check engine light?
  2. Mar 28, 2011 at 2:44 PM
    n315on
    MA
    02 4x4 SR5
    Ohhh i forgot to mention, I'm open to all other options.
  3. Mar 29, 2011 at 5:50 PM
    n315on
    MA
    02 4x4 SR5
    anyone?
  4. Mar 29, 2011 at 6:02 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    you could run with both cats or without them and run the simulator.or an aftermarket cat and the simulator. the simulator turns off P0420 only so as long as thats the only code your gettin,your good to go.
  5. Mar 29, 2011 at 6:06 PM
    n315on
    MA
    02 4x4 SR5
    Ok thats exactly the answer i was looking for. Thank you! Ill probably end up going with the aftermarket CATS just to get a deep sound.
