URD 7th injector kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rmartin517, Oct 26, 2016.
  1. Oct 27, 2016 at 12:15 PM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    Me: No ping, Ik22s, no 7th injector, og pulley. From what I've read, you should run the smaller pulley with the 7th injector. Otherwise, I wouldn't mess with your setup since its running fine.
  2. Oct 27, 2016 at 12:16 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Gonna need the 7th then. No way would id run a smaller pulley with no fuel mods
    TashcomerTexas likes this.
  3. Oct 27, 2016 at 12:28 PM
    Rmartin517
    Rmartin517 [OP] Well-Known Member
    Robert
    Texas
    2001 4 door Tacoma limited trd
    Supercharger, 6" fab tech, 20" moto metal wheels, 34" Nitto trail grapplers
    No I'm not. I'm gonna do both. I just keep getting a check engine lean on bank one code.
  4. Oct 27, 2016 at 12:28 PM
    anthony250f
    Anthony
    San Diego, CA
    Could be o2 sensor
  5. Oct 27, 2016 at 1:03 PM
    Rmartin517
    Robert
    Texas
    That's what I was thinking but it's just started after the SC install. I have been looking for air leaks. Used all new gaskets to. Also spared car cleaner around everything and I'm not getting and change in idle. Going to start checking hoses next I guess.
  6. Oct 27, 2016 at 1:39 PM
    anthony250f
    Anthony
    San Diego, CA
    Check the nipple on the back. The "boost port"
  7. Oct 27, 2016 at 1:39 PM
    anthony250f
    Anthony
    San Diego, CA
    Also check the nipple next to the throttle body
  8. Oct 27, 2016 at 1:44 PM
    eon_blue
    Azusa, CA
    Wait, you're getting a P0171 code? 'System too lean bank 1'? I had that code too shortly after I got my truck, took forever to figure out but eventually a Master Tech at Toyota discovered that a port on the back of my supercharger was uncapped, they capped it and the code went away. It's actually quite common, get it checked!
  9. Oct 27, 2016 at 1:47 PM
    eon_blue
    Azusa, CA
    I took it to 3 dealerships for my P0171 code and 2 of them sent me away because they couldn't figure it out, one of them even told me I needed to get rid of the supercharger. They replaced my MAF sensor, 02 sensor, A/F sensor, spark plugs and wires, etc. and nothing solved the code. Eventually the third dealership had the Master Tech that was familiar with the superchargers and he diagnosed it right away. Dollars to donuts that's what's up with yours as well. There's actually a few threads on here from guys with the TRD supercharger that had the same thing happen to them, uncapped port on the back of the supercharger.
    Yep @anthony250f is right, that's the port.
  10. Oct 27, 2016 at 1:49 PM
    Rmartin517
    Robert
    Texas
    Yeah I'm cutting the ends and getting good rubber on all my fittings and I'll check that port also. Thanks.
    eon_blue likes this.
  11. Oct 27, 2016 at 1:51 PM
    eon_blue
    Azusa, CA
    Now that I think about it there's 2 ports back there I believe, the boost port then there's another one to the lower left side of it I think, the EGR port maybe? That was the one I needed to cap. But either one could throw the code if it's not properly sealed
  12. Oct 27, 2016 at 2:18 PM
    Rmartin517
    Robert
    Texas
    It's sucking air through the the waste gate when it's closed.
  13. Oct 27, 2016 at 2:20 PM
    anthony250f
    Anthony
    San Diego, CA
    Not good...time for e new one. It's called a bypass valve
  14. Oct 27, 2016 at 2:23 PM
    eon_blue
    Azusa, CA
    hmm, I should check my bypass valve too. Someone mentioned to me that it not working properly could be why I'm seeing little to no boost in first gear. It opens/closes like it should but I haven't checked to see if it's sucking in air when closed or not.
    Was told I could try unplugging the vacuum line going to the bypass valve and driving it a short distance to see if that solves the issue, still need to give that a try
  15. Oct 27, 2016 at 2:24 PM
    #35
    anthony250f
    Anthony
    San Diego, CA
    To test it you can pull the plunger out. Plug the nipple. And see if it holds
    eon_blue[QUOTED] likes this.
  16. Oct 27, 2016 at 2:31 PM
    #36
    Rmartin517
    Robert
    Texas
    I sprayed carb choke cleaner around everything and it idles the motor up around the plunger and with the port plugged on the SC it runs better no loping or anything.
  17. Oct 27, 2016 at 2:42 PM
    #37
    Rmartin517
    Robert
    Texas
    Yeah the plunger does not hold at all. Where can I buy a new one and will it be ok to drive. If I drive it should I plug the supercharger nipple just leave it all hooked up.
  18. Oct 27, 2016 at 2:59 PM
    #38
    eon_blue
    Azusa, CA
    Should be able to buy the bypass valve through Magnuson since they make that supercharger. I imagine you're fine to drive it around, just try to keep it out of boost.
  19. Oct 27, 2016 at 3:04 PM
    #39
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    I don't understand how people w/o the 7th injector can give any input on this; yes it is a must, the extra fuel delivery will keep everything in check. Original pulley you'd be fine. 2.2 and definitely the 2.1 you'll need more fuel.
  20. Oct 27, 2016 at 3:08 PM
    #40
    Rmartin517
    Robert
    Texas
    Just ordered it that was the problem. It's Boostign some but I can't wait till I gets full boost. Probably explains why I'm getting absolutly no ping.
