URD 7th injector kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rmartin517, Oct 26, 2016.
  1. Oct 30, 2016 at 8:12 PM
    #81
    Rmartin517
    Rmartin517 [OP] Well-Known Member
    Robert
    Texas
    2001 4 door Tacoma limited trd
    Supercharger, 6" fab tech, 20" moto metal wheels, 34" Nitto trail grapplers
    I guess some of the 4 cyl tacoma and 4 runners. Even found some with 4.88's. I asked for door tags and received photos of the door tags and cross referenced them.
  2. Oct 30, 2016 at 8:18 PM
    #82
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Hmm I would def count teeth when you pick them up
  3. Oct 30, 2016 at 8:20 PM
    #83
    Rmartin517
    Robert
    Texas
    Oh yeah for sure. 4.56 seems to be the more common on a 5 speed Tacoma. I found one with a e locker too. My truck has an e locker. I probably shoulda bought it.
  4. Oct 31, 2016 at 7:08 AM
    #84
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I think it depends on how many wires your O2 sensor has...4 wire = Wideband
    I looked into this route, but just couldn't find anything available at the time I was regearing. Also, just make sure if you have the stock E-Locker that you get a 3rd that that is also stock e-locked. THe axle housing are different for the locked vs non-locked rear ends.
  5. Oct 31, 2016 at 7:42 AM
    #85
    Rmartin517
    Robert
    Texas
    Yup and I missed a stock 4.56 with e locker. As of now with the 34's w/ 4.10's and only 2.5 lbs of boost at 70mph I'm at 21-2250rpm and over drive holds fairly decent but I find that it's hunting once I get into a lot of over passes one after another.
  6. Oct 31, 2016 at 9:18 AM
    #86
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    boostedka[QUOTED] likes this.
  7. Oct 31, 2016 at 10:37 AM
    #87
    boostedka
    James
    NM
  8. Nov 1, 2016 at 6:26 PM
    #88
    Rmartin517
    Robert
    Texas
    What's the deal with the TRD Ecu. If one has a TRD truck is it equipped with the TRD Ecu or is that and ad on?
  9. Nov 2, 2016 at 1:06 PM
    #89
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    No such things as a TRD ECU, period.
    edit: there is LOL
  10. Nov 2, 2016 at 1:07 PM
    #90
    Rmartin517
    Robert
    Texas
    #90
    TXpro4X4 likes this.
  11. Nov 2, 2016 at 1:10 PM
    #91
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Well I'll be damned. Is it a reflashed stock ECU for a S/C equipped truck? Does anybody actually know?
  12. Nov 2, 2016 at 1:11 PM
    #92
    Rmartin517
    Robert
    Texas
    Kinda what I was getting at.
  13. Nov 2, 2016 at 6:35 PM
    #93
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    It is a early non tunable version of the split sec computer, basically. Something they tried to do for dealer installs.
  14. Nov 2, 2016 at 6:37 PM
    #94
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    I'm not aware of what capabilities split second has. Thanks for the answer though. Never knew such a thing existed.
  15. Nov 2, 2016 at 6:50 PM
    #95
    Rmartin517
    Robert
    Texas
    Finally got my wastegate/ vacuume actuator. I'm putting out about 6lbs of boost not sure if this cheap gauge is really accurate but it did make a diff. I'm pretty happy Still have no ping. Still think I am gonna go for the 7th and a 2.1 pulley. I guess WĂŠE all always just want more. Until then I'm pretty happy with my build. Thanks for all yalls help. I really appriciate it. Did the grey wire mod today too. Now I just need to figure which gears I want to go with. I'm thinking of stepping down to a 33" tire so I can get a passenger tire. These 34's are load range e and ride pretty rough. I'm kind of considering goibg from 4.10 to 4.30 Toyota gear swap it's cheaper and easy swap. I know everyone says 4.56 by I think that's gonna be to low for my driving. My truck is just right there on the edge of needing just a little bit lower gear.
  16. Nov 2, 2016 at 6:58 PM
    #96
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    There's not.
    there is no reflash for 1st gen trucks. Just because a link labels it as such doesn't make it a thing. It would be like me selling my ecu and titling it "trail teams ecu" just because I can.
  17. Nov 3, 2016 at 7:19 AM
    #97
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Thanks for your input. The only thing I'm aware folks have done with the stock ECU is re-PROM it so this was really curious to me. The only thing that throws me about that ECU is that it's wrapped in a nonstock TRD box that looks pretty legit.
  18. Nov 3, 2016 at 7:27 AM
    #98
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    #98
  19. Nov 3, 2016 at 7:32 AM
    #99
    Rmartin517
    Robert
    Texas
    I did some research and apparently it's a discontinued item. Not sure what the difference is.
  20. Nov 3, 2016 at 7:32 AM
    #100
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    In any case, definitely don't buy it. Who knows WTH it does (though I really wish some OG would say definitively what it does and how many were made) It even looks like seller has 2 of them, serial numbers #165 and #359 You'd be better off getting an AEM FI\C 6, or whatever calibrator goes with the 7th kit.
