URD 7th injector kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rmartin517, Oct 26, 2016.
  1. Nov 17, 2016 at 9:09 AM
    #121
    eon_blue
    Azusa, CA
    I'm not familiar with the fuel pumps I just know that they're highly recommended for the smaller pulley and the 7th injector is a must. Call Gadget at URD and he'll sort you out. Like @Clay_916 said above though, stick with the 2.2 pulley
  2. Nov 17, 2016 at 7:53 PM
    #122
    03 taco
    03 taco Active Member
    orange county, ca
    03 4x4 sr5 v6 trd
    trd supercharger, trd headers, 7th injector, injen intake, magnaflow exhaust
    Thanks for the info eon_blue and clay_916 I definitely call urd
  3. Nov 18, 2016 at 6:24 PM
    #123
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Originally the URD kit (6 injectors not 7th) came with a Walbro 190 fuel pump. I've had mine in since '04 and its plenty as well as a drop in.
  4. Jan 11, 2017 at 9:45 AM
    #124
    shootmymime
    shootmymime Well-Known Member
    Idaho
    00 4Runner
    So ive got a couple questions to bring this back.
    Background on my truck. 2000 4runner, sc, 2.2, 7th, ik22, walbro 190, 91 octane fuel, 170 t-stat, 4,200 ft. 35's tires on stock gearing (limited so i believe its 4.10s)
    My problem is with these larger tires driving at 65 mph my engine sits at 1800-2200 rpm and thats the perfect place for HGLR ping. i have heard ping previously before the 7th, but i am now (past year been fighting this) getting a knock sensor bank 2 code which causes the truck to retard timing and go into limp mode. I have replaced the knock sensor and wire harness with no change, same problem.
    my timing from the 7th map A keeps me at 20 deg (+,- 2 deg) which is supposed to be perfect. i have also changed the overage pressure from 3 to 2 which is the fuel enrichment to start at 2 psi in the vehicle (thats not the 7th injector yet)
    another problem that i have is i believe my high rpm timing is off. iirc reading ether urd, speedy or TxACE that on the dyno they found that 20 deg was the best place for timing to get the most power. mine showing on the ultra gauge reads 13-15 in high boost and looking at map A timing is all 0 meaning no changes. Ive had to add fuel as well. about 15% across the table. afr now read high 10 and low 11 in boost.
    so what do you recommend for my hglr ping and what should my timing be at high boost for more power?
  5. Jan 11, 2017 at 10:33 AM
    #125
    elnip
    LC,NM
    With the 3.4 being all over the map with regards to pinging, I would suggest you focus on the cells in that 1800-2200 rpm area and not focus on the 20 deg timing.
    For example, when my truck did ping it was in the 2600-2900 rpm area and retarded timing in those cells. I had zeros everywhere else. Now I have W/I and don't run any
    retard anywhere.
    You said you have replaced the knock sensor but there are two. A few people have converted over to the Wells GM knock sensor SU1075 after issues you describe but I can't speak for that.
  6. Jan 12, 2017 at 7:30 AM
    #126
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I would also recommend switching to the GM SU1075 knock sensors as well. They are less sensitive and less likely to over retard your timing
    elnip likes this.
  7. Jan 12, 2017 at 8:25 AM
    #127
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I gotta do this. I have my bad sensor bridged to my good sensor at the ECU, not the best idea. I keep saying next time I'll do this next time I need to do anything under the hood, but you know- Toyota.
  8. Jan 12, 2017 at 9:53 AM
    #128
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    You're in 11 afrs when it's HGLR pining?
  9. Jan 12, 2017 at 9:56 AM
    #129
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Who are you asking? And what's HGLR?
  10. Jan 12, 2017 at 9:57 AM
    #130
    boostedka
    James
    NM
    High gear low rpm I'm guessing
    vasinvictor likes this.
  11. Jan 12, 2017 at 9:58 AM
    #131
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    @shootmymime
  12. Jan 12, 2017 at 10:03 AM
    #132
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    ok yeah, I'd like to know too. Do you have the ability to tune closed loop boost, and is it in the 10-11 range when it's pinging? That seems unlikely to me, regardless of timing being pulled or not. You've realized by now that some of these trucks are just super ping happy. I'll check on my total timing in open loop high RPM, but it's definitely down near 15* or less.... not 20
  13. May 25, 2017 at 10:24 PM
    #133
    eon_blue
    Azusa, CA
    Hey @Rmartin517 did you ever get that used 7th injector kit installed? How's it worked out for ya? I finally pulled the trigger on a new complete kit through URD, hopefully going to get it installed soon.
  14. May 26, 2017 at 5:37 AM
    #134
    boostedka
    James
    NM
    Did you get a smaller pulley as well?
  15. May 26, 2017 at 9:31 AM
    #135
    eon_blue
    Azusa, CA
    nah just the 7th injector, I've had pretty bad pinging issues for the past year or so on my stock s/c charger setup, despite always running 91 and having colder plugs. Hoping the URD kit helps as advertised, if it does I'll look into upgrading the pulley eventually.
    I have to be careful with the upgrades though as I live in CA and even the 7th injector kit will make me fail a smog visual if the tech cares enough. I've heard it's 50/50 out here, just have to find a shop willing to overlook it or not realize what it is. Worst case scenario I unhook it for the test.
    boostedka[QUOTED] likes this.
  16. May 26, 2017 at 7:03 PM
    #136
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    So......After all the 7th injector talk. What kind of fuel are you using?? I like to mix my own to what my map calls for! I data logged like for like 6 months and used wide-band tuner to tweak my map. I found the biggest thing was the fuel mix. E10 makes 15% less power than regular fuel and is less likely to ping. 91-93 non-ethanol has to much power and burns much hotter and faster and can ping more due to heat from hotter fuel. But i find if i mix 89 regular non-ethanol fuel with 91-94 octane E10 I get a perfect blend of 90-91 and at 7800 ft above sea level it has ZERO PING! I have the 7th, the 2.1 pulley, Crank pulley, ported polished supercharger intakes, Hy-brid bearings in the supercharger, Trd headers, custom collector and 1 high-spun Catalytic converter and 3" of straight pipe into a series 40 flow-master 3" inlet and 3" outlet. And 4:88 on 37's.
    You may end up trying a MAF calibrator or maybe even a stand alone system.
    QMEDJoe and boostedka like this.
  17. May 29, 2017 at 4:46 PM
    #137
    eon_blue
    Azusa, CA
    Just got my 7th injector kit installed yesterday, driven it a couple hundred miles so far and all I have to say is WOW. This must be what the 5VZE supercharger was supposed to feel like all along :D Finally no more pinging; I was dealing with major pinging issues especially in the high gear/low RPM range and when going up any sort of incline while in boost...that's almost completely gone now (still get a couple pings when slamming the pedal to the floor but it quickly goes away, that's to be expected from what I've read). Highly recommend this kit to anyone with a lean/pinging issue and wondering whether or not to pull the trigger...do it!
    QMEDJoe likes this.
  18. May 30, 2017 at 2:21 PM
    #138
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    The 7th injector only enriches open loop fueling. It's a pretty sloppy fix IMO. It's good to hear you're having success, I'm just trying to avoid spreading of misinformation.
  19. May 30, 2017 at 2:23 PM
    #139
    eon_blue
    Azusa, CA
    I've been hard on the throttle the past few days that it's been on and I haven't experienced any of the pinging I was getting on a daily basis beforehand, it did exactly what was advertised for me. Not saying it will solve everyone's issues but it was worthwhile in my case.
  20. May 30, 2017 at 2:30 PM
    #140
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    The URD FTC that comes with the 7th kit retards timing under boost. It's basically taking power away to avoid detonation caused by a mechanism intended to make more power. I'm not certain but if there were a way to pair an o2 sensor skewing device into the system I think it would be a much more complete solution. IMO closed loop response with a SC setup is paramount.
    eon_blue[QUOTED] likes this.
