URD 7th injector kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rmartin517, Oct 26, 2016.
  1. Aug 19, 2019 at 11:28 PM
    #161
    recoilfx
    recoilfx New Member
  2. Nov 7, 2019 at 4:37 AM
    #162
    1997tacomav6
    Denver
    So this is a separate unit that could be used with a methonal setup?
    How hard is it to install.
    Any writeups.
    ChargedSHOTaco likes this.
  3. Nov 7, 2019 at 9:28 AM
    #163
    eon_blue
    Azusa, CA
    This is exactly what I need to do. The damn software for the 7th injector is so old though that I need to get an older Windows laptop somehow to do it with. But I get bad pinging in closed loop still, open loop I'm totally fine with the 7th but under 2500 RPMs at 1 - 3 PSI I get pinging bad especially if it's hot outside.
    I think I'm finally motivated enough to track down a shitty old laptop so I can finally do this
  4. Nov 7, 2019 at 9:35 AM
    #164
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yeah I hated using that software to tune my 7th
  5. Nov 7, 2019 at 9:38 AM
    #165
    eon_blue
    Azusa, CA
    I should actually be able to do it with my Mac laptop by running an older version of windows on it, a fellow member gave me the download link for it awhile back I just have to figure it out.
  6. Nov 8, 2019 at 7:38 PM
    #166
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Yes. No reason for it though if you have a good AFR over your entire boost range and no ping.
    1997tacomav6[QUOTED] likes this.
  7. Nov 8, 2019 at 7:44 PM
    #167
    kigmob
    James
    New Orleans
  8. Nov 8, 2019 at 7:46 PM
    #168
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    it’s the URD AFR calibrator. With the 7th it’s built in but not user programmable. You get 13.5AFR in closed loop when you set it to come on.
  9. Nov 8, 2019 at 7:48 PM
    #169
    1997tacomav6
    Denver
    Can you set it lower for the option kit?
  10. Nov 8, 2019 at 7:50 PM
    #170
    1997tacomav6
    Denver
    I have no pinging and runs fantastic, but when in closed loop with boost the AFR is more lean, that’s all
  11. Nov 8, 2019 at 7:51 PM
    #171
    Shortman5
    Supercharged TRD
    With the 7th you can set it to turn on at any psi. With the AFR cal you have a map that allows you to add fuel anywhere in boost. But there is a limit. Supposedly it’s below 12.8 then you may get a light which is why 13.5AFR was chosen for the 7th.
  12. Nov 8, 2019 at 7:53 PM
    #172
    1997tacomav6
    Denver
    Well the problem with that is that close loop comes on at different times and different boost.
    It’s not consistent depending if it’s luging or high rpms.
    But it should still help? The transition from closed to open loop?
  13. Nov 8, 2019 at 7:59 PM
    #173
    Shortman5
    Supercharged TRD
    It shouldn’t be an issue. You’ll have a map based on boost and RPM. Add fuel where you want it.
  14. Nov 8, 2019 at 8:05 PM
    #174
    1997tacomav6
    Denver
    Have you installed one?,
    I could not find an install on this item or how or where it’s connected.
    6 wires I think
  15. Nov 8, 2019 at 8:08 PM
    #175
    Shortman5
    Supercharged TRD
    One wire is power
    One is ground
    One is tach
    One is for AFR
    Don’t use the rest.
  16. Nov 8, 2019 at 8:09 PM
    #176
    Shortman5
    Supercharged TRD
    but since you’re pre AFR and dual cat you need a different one. It’s on URDs website I just forgot what it’s called.
  17. Nov 8, 2019 at 8:09 PM
    #177
    1997tacomav6
    Denver
    Nice
  18. Nov 8, 2019 at 8:12 PM
    #178
    1997tacomav6
    Denver
    I’m single cat setup, There’s a different 02 model for the 1997 and the 2000 forwards I think
  19. Nov 8, 2019 at 8:19 PM
    #179
    1997tacomav6
    Denver
    Oops,
    I was referring to the https://www.urdusa.com/urd-o2-sensor-calibrator/
    To richen up the closed loop section when Boost starts in closed loop
    Not the AFR calibrator
  20. Nov 8, 2019 at 8:27 PM
    #180
    Shortman5
    Supercharged TRD
    Then that unit probably intercepts instead of taps. So power, ground, tach, unit wire to o2, unit wire to o2 ECU pin.
