URD Cam Gears
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Jan 12, 2025.
  1. Jan 12, 2025 at 1:49 PM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    I have a 2011 4.0L, and I need to change my VC gaskets. While I'm in there, I considered installing the URD cam gears. Do these ACTUALLY help? Like, more than just a placebo thing? I'm not expecting them to feel like a supercharger, or magically get hybrid MPG. But do they really make a difference that's worth the time and money?
  2. Jan 12, 2025 at 2:15 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    @Torspd
    I've read results that show actual increases. Not large, but real.
    Torspd and TegoTaco like this.
  3. Jan 13, 2025 at 1:25 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Very happy I did so and especially if you are replacing valve gaskets which gets 90% of the mod finished anyway. I did the cam gears, manifold spacer and OTT tune all around the same time as well as spark plugs and other normal maintenance
    World of difference. Heres one thread and there is another really long one detailing everything you need to do. https://www.tacomaworld.com/threads/urd-cam-gears-ott-tune.844461/#post-30206101
    Rob MacRuger likes this.
  4. Jan 13, 2025 at 2:31 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes they do help. @JustDSM with OTT tuning, has dyno'd them i believe. Regardless, from all of the tuning before and after those being installed, they do make a difference. That difference is most noticeable after a tune for them though.
  5. Jan 13, 2025 at 2:46 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Unfortunately, my 1GR N/A testing has had to be put on temporary hold. I have the URD Gears for my 2014, but I've not yet installed them. I will get back to the 1GR N/A Development, but, I've got my hands full with the 3G Tundra/4G Tacoma/LC250/and 6G 4Runner development.
    I'm certain they make power, but I don't have data to share for exactly how much now.
    Torspd and Dm93 like this.
  6. Jan 13, 2025 at 3:34 PM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Here is the big thread - https://www.tacomaworld.com/threads/cam-gears-for-v6-add-power-and-mpg.618266/
    Torspd likes this.
