URD competition Y-pipe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gottaToy, May 9, 2015.
  1. May 9, 2015 at 5:19 AM
    gottaToy
    gottaToy [OP] Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    The picture on the website sucks and isn't even of the right product, so here is what it REALLY looks like. This is for a 2015. It uses a larger pipe, smoother bends, deletes 2nd cats, and adds ground clearance by not going under the trans mount cross member. Seems to add a little more throttle response, even with an already installed cat back system.
  2. May 9, 2015 at 5:41 AM
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Interesting for a Y pipe reroute option. What's the price?
  3. May 9, 2015 at 7:51 AM
    gottaToy
    JJ
    1985 Moped
    $445. the doug Thorley is $301, but has some crazy bend from the drivers side because the fit the resonator in there, and I'm guessing they run it up and behind the cross member. That or it will be hanging way down under it, which would be sure to be crushed when off roading. I'd say that is more for the 2 wheelers and street use. The URD is more straight flow design and a 20" mbrp resonator can easily fit in front of the muffler if you want to reduce drone, which the muffler choice has a large effect of anyway, not so much the y-pipe.
  4. May 11, 2015 at 1:35 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    This basically re-routes your exhaust form that hang that eventually will get smashed, nice! This may be my next purchase. Do you notice much difference in noise or anything with the rear cats deleted? Performance?
  5. May 11, 2015 at 5:33 PM
    gottaToy
    JJ
    1985 Moped
    I've had a lot of cars that I've put performance exhaust on, and the more you free them up, they always are louder. How much depends on all the components together. I already had a cat back, and this made is a little louder, but not really any drone. The drone seems to come in more with muffler and tailpipe exit choices. I would imagine with a stock exhaust or the TRD catback, this wouldn't make it much louder as those are pretty restrictive and still rather small diameter pipe. There is a little more throttle response, more than when I did the catback. Seems most cars you get a little with a CB, but I didn't really notice any performance difference until the y-pipe
  6. May 11, 2015 at 6:04 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I've had one for six or seven years. It's solid upgrade, and getting the boat anchor of a factory exhaust rerouted is worth the money. I saw someone smash one once, and their truck died (too much back pressure). It was in a nasty mudhole with rocks all over and he had to slide under the truck in 10" of mud with a hacksaw blade (no hacksaw of course!) and cut the pipe to get the taco to start and get it out of there. The performance gains are mostly around redline, but it's good for a few ponies.
  7. May 12, 2015 at 7:38 AM
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    will this work with my TRD cat back that's already in there?
    not smashing things off road is nice.
  8. May 12, 2015 at 12:32 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Yes.
  9. May 12, 2015 at 1:28 PM
    Iggy
    Iggy Vagabond Outdoors
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I'm guessing this is not carb legal?
  10. May 12, 2015 at 1:48 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    For offroad use only. That said it will not throw a code and looks "stock", especially once you cover it in some road grime.
  11. May 12, 2015 at 1:56 PM
    Iggy
    Northern CA
    Check out the build
    Thanks @username! Does anyone have a pic of where the pipe crosses?
    I'm thinking about how tight that area maybe and what heat it causes with skid plates.
  12. May 12, 2015 at 2:44 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I'll do some digging and see if I do, but I don't think so.
    Stock pipe, with aftermarket dent (mine)
    N/Es06 likes this.
  13. May 12, 2015 at 2:50 PM
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    So are you saying it would be ok on a smog check? Or is that just for where you are and not in CA?
  14. May 12, 2015 at 2:57 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I'm saying when I lived in SoCal I passed no problem. I also went to the dirty sanchez test facility in Victorville. If you fail, just bolt your old one on and retest.
  15. May 12, 2015 at 10:03 PM
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Hmm Definitely something to consider since I was planning on spending the money to re-route that part anyways. Thanks for the insight!
  16. May 12, 2015 at 10:06 PM
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Do you have any pictures of the y-pipe installed?
  17. May 13, 2015 at 12:38 PM
    WhiteNemesis
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Would like to see as well
  18. May 13, 2015 at 4:12 PM
    gottaToy
    JJ
    1985 Moped
    I'll get some when I junk my flowmaster and install the URD 3" catback I ordered
  19. May 13, 2015 at 11:01 PM
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    :thumbsup:
  20. May 22, 2015 at 5:47 AM
    gottaToy
    JJ
    1985 Moped
    Still waiting on my URD Catback:mad: I seem to be getting the runaround from URD. The Y-pipe came within 2 days, but after hearing nothing for almost a week, I've called and been told they were back ordered and were being shipped Wednesday and I should get my tracking info. I've got nothing, which you have to sign for it when they deliver it, so it sure sucks when stuff shows up unexpected and no one is around to sign for it. Seem to be mixed bag of personalities that work there, one guy will be really nice, and the next a complete ass. I like the y-pipe and excited about getting the catback, sure hope I like it.
