URD o2 sim and emissons question
Discussion in 'Technical Chat' started by hsc001, Jun 8, 2009.
  1. Jun 8, 2009 at 9:25 PM
    hsc001
    hsc001 [OP] Well-Known Member
    laurel, Maryland
    08 TRD off road lifted
    BHLM, 3" toytec coilovers, blacked out billet grille, hella 500's behind grille, volant CAI, Dual flowmasters 40's, HID, DTLT
    I have a question about the URD o2 sim and emissons. I want to buy a set of doug thorley long tubes with either the URD competition y pipe or the tacoma pipe bomb y pipe. I know the DTLT headers will eliminate my front two cats, and both the competition y pipe and pipe bomb y pipe will eliminate the last two. In Maryland the emissions test involves a gas cap test and hooking the vehicle up to a computer to check for any problems. My question is will the URD o2 sim allow me to pass Maryland emissions? If not what can i do to pass emissions and run the set up i want to? thanks in advance.
  2. Jun 8, 2009 at 10:45 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    The O2 simulator just tells the computer everything is clean and fine with the exhaust. If MD does any sort of Carbon Monoxide sniffing, you'll most definitely fail.
  3. Jun 9, 2009 at 5:44 AM
    hsc001
    laurel, Maryland
    nope MD just hooks your car up to a computer and puts a hose in your gas, and the people that work there dont know what to look for. awsome it sounds like im good to go on my headers and y pipe
  4. Jun 9, 2009 at 7:02 PM
    hsc001
    laurel, Maryland
    any one eles have any input?
  5. Jun 9, 2009 at 7:16 PM
    98tacoma27
    Ben
    Not Beech Creek
    Do they require the emissions system be complete?
  6. Jun 9, 2009 at 7:34 PM
    hsc001
    laurel, Maryland
    what they dont know wont hurt me. the only emissions test that worries me is the computer test. I need to find some way to fool there emissons diagonostic. And my question is will the URD o2 sim do that for me even when im running 0 cats
  7. Jun 9, 2009 at 7:39 PM
    98tacoma27
    Ben
    Not Beech Creek
    Chances are the will put the truck on a lift and inspect it. In PA they pull wheels to inspect a back and a front brake. They also check for exhaust leaks. I imagine they would do the same in MD. And if they see you don't have a CAT they might fail it.
  8. Jun 9, 2009 at 7:56 PM
    hsc001
    laurel, Maryland
    I think your getting inspection and emissions mixed up. Inspection is were a inspector looks over every part of your vehicle and determines if it meets your states requirments to be on the road. Emissions in MD just checks your vehicles computer to see if your throwing any codes. Anyways the emissions people get alot of cars around emissions time and just speed threw each car. And 9/10 those guys dont even know what to look for.
  9. Jun 9, 2009 at 8:01 PM
    98tacoma27
    Ben
    Not Beech Creek
    They do them both at the same time here. I see your point though. Yes the O2 sim tricks the ECU with regards to the CAT. But I think you will need a sim for each O2 sensor.
  10. Jun 9, 2009 at 8:12 PM
    hsc001
    laurel, Maryland
    so the o2 sim should work, awsome. do you know how many o2 sims are on a 06+ truck?
  11. Jun 10, 2009 at 12:20 AM
    johnecon2001
    Phoenix, AZ
    You just need the Dual Channel one from URD. Just one of those will do the trick.
  12. Jun 10, 2009 at 3:45 PM
    hsc001
    laurel, Maryland
    cool thanks
