URD Short Shifter Installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rlotti, Mar 14, 2011.
  1. Mar 14, 2011 at 8:46 PM
    rlotti
    rlotti [OP] Well-Known Member
    Bay Area
    05 prerunner trd
    Jardine exhaust, Fujita intake
    I instaled a URD short shifter recently. Finally broke it in, but now it is hard to get into 2nd gear. I also did not check the level of the oil in the gearbox when I did my install. Did anyone who has done this taken pictures of the level of the oil? If so please PM me. Thanks
  2. Mar 14, 2011 at 8:51 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    For me, it helped that I installed an aftermarket shift knob. It's heavier so it helps with the momentum
  3. Mar 14, 2011 at 8:54 PM
    Cuda444
    Cuda444 Well-Known Member
    New England
    TRD Off-Road
    Access Limited Bed Cover, URD Short Shift Kit, 25% Tint all around, WeatherTechs, Kenwood DNX-6160, 2 - IDQ10 sub, Hybrid Audio Clarus 6.5's, JL 500/1, JL 300/2, Mr.Marv Enclosure/Amp Rack, Morimoto Stage III Retro Headlights, Blazer Fog Retro
    Haven't had any issues with mine getting into any gear. Reverse is the only known "Issue" that I found... the solution is you kind of slap the lever over into reverse. Trouble getting it into second doesn't sound right. Have you taken it apart and put it back together since? Just to be sure.
  4. Mar 14, 2011 at 8:59 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" TuRD PRO replica wheels
    Are you talking about the little bit of gear oil that is around the base of the shifter? I think that just gets 'splashed' up there and I don't really think you have to add any. The fill plug is only about half way up on the side of the transmisson.
    When I did mine I cleaned it all up with a rag.
    If you want I think you could take it back apart and put a little white lithium grease on the ball if you think that will help.
