URD Short Throw Shifter 2.7 Tacoma
Discussion in 'Performance and Tuning' started by ProCompTacoma, Sep 14, 2009.
  1. Sep 14, 2009 at 8:07 AM
    ProCompTacoma
    ProCompTacoma [OP] Member
    Hello Guys-
    I have a 06 Tacoma Reg Cab 2.7L 5speed MT. My question is will the (URD Short Throw Shifter 2.7 Tacoma) fit my truck?
    Thanks for your input
  2. Sep 14, 2009 at 8:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Probably better off contacting URD.
  3. Sep 14, 2009 at 8:12 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Yes, it should.
    However, there have been a few issues (mine included) where the shifter was too large in diameter for the spacers in the kit. There's a thread around here somewhere about this. Gadget offered to refund the kit, but as another user did on here, I used a dremel to shave down the spacers and made it work. I'll try and find the thread.
  4. Sep 14, 2009 at 8:16 AM
    afd23a
    The Dynamo of Dixie
  5. Sep 14, 2009 at 8:23 AM
    ProCompTacoma
    Guys-
    Thanks for the quick response.
    afd23a-
    If only I could find the thread how to install\Shave that would help alot. I have already placed the order but I want to make sure the part will work for you truck.
    Thanks man
  6. Sep 14, 2009 at 8:23 AM
    ProCompTacoma
    Thanks bud...
  7. Sep 14, 2009 at 8:24 AM
    ProCompTacoma
    afd23a over all how do you like the mod? Is it better than stock?
  8. Sep 14, 2009 at 8:46 AM
    afd23a
    The Dynamo of Dixie
    Yes, it is an improvement over stock. I would do it again. The throws are shorter and tighter. Don't expect it to shift like something it's not (a sports car with fancy synchros) but it is a definitely a very noticeable improvement.
    As for modifying the spacers, you can't do much about it until you get the kit. Take your time and remove the shifter and check the spacers on the shaft. If the extension won't fit completely over the spacers and onto the shaft, then the spacers will have to be shaved down or go without the short shifter. I carefully sanded/ground the inside of the spacers (the part that touches the shifter) until the extension fit over them. A dremel makes the task much easier. I wouldn't attempt modifying it if you're not comfortable with the risk.
