URD Y Pipe install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vitalzone, Feb 13, 2017.
  1. Mar 4, 2017 at 6:55 AM
    #61
    austinklindsey
    austinklindsey Well-Known Member
    Austin
    2016 4Runner SR5
    Toyo AT, Rola Rack
    That's kind of what I'm thinking. My friends exhaust shop is pretty talented. I'm curious to know if the majority of the power increase comes from the removal of the cats or from less evasive "turn" in the new pipe. Removing the cats would be pretty easy for my guys but I'm not sure about the split in the pipe
    rlx02 and Joe23[QUOTED] like this.
  2. Mar 4, 2017 at 7:28 AM
    #62
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    only thing that is really appealing to me about the URD one is that its stainless steel and TIG welded.
    Most fab shops will not be using stainless and their welds would be MIG.
  3. Mar 4, 2017 at 8:23 AM
    #63
    austinklindsey
    Austin
    2016 4Runner SR5
    Toyo AT, Rola Rack
    Yeah those are two pretty nice qualities! I asked URD on their FB page if there is any power gains and/or proof and they won't respond...
  4. Mar 4, 2017 at 8:38 AM
    #64
    Swiftks
    Swiftks Well-Known Member
    Spring, TX
    2016 TRD OR
    Bilstein 6112 (front) Bilstein 5160 (rear) Headstrong Progressive AAL ShiftSense Pro SumoSprings BakFlip F1 Tonneau Cover BAMF Grille aFe intake w/ scoop Custom Exhaust - URD Y-Pipe, Vibrant Ultra Quite Resonator & MagnaFlow Muffler 4Runner TRD Pro 17" Wheels Wrangler DuraTracs - 265/70R-17 Redline Hood Struts OPT7 LED Headlights (Highs & Lows) Baja Designs Squadron Pro Fog Lights LED Interior Lights Total Chaos Bed Stiffeners TRD Pro Skid Plate TRD Pro Tail Lights TRD Pro Shift Knob @CBoy808 Custom Bedside Decals FormulaOne Pinnacle Window Tint OEM Tacoma Bed Mat OEM Tacoma All Weather Floor Mats Fumoto Valve Amsoil Fluids
    Also, don't forget it's all mandrel bent piping too. It would be pretty easy to do a custom y-pipe (just look at the the exhaust re-route thread)... But if you wanted a custom y-pipe that was thick 304 stainless, which removes cats, add O2 bungs, is TIG welded, and Mandrel bent... that's probably going to cost over $500. And that's if you can find a shop that even has a Mandrel bender. Houston has one, and they wanted $1200 for a custom exhaust; I know because I called and asked before ordering all my parts.
    Joe23[QUOTED] likes this.
  5. Mar 4, 2017 at 9:20 AM
    #65
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    If you will look at the 5th dyno on this link you will see a 28-29HP gain with the URD y pipe on the 4.0 engine from a TW member. The gains should be similiar on the 3.5 since they primarily come from removing the cats and secondarily from the reroute.
    https://www.tacomaworld.com/threads/n-a-power-gains-dynos-w-mods.229882/
    edit, sorry for forgetting the link.
  6. Mar 4, 2017 at 9:30 AM
    #66
    Swiftks
    Spring, TX
    2016 TRD OR
    1) There are no instructions... Zero.
    2) I already knew what the "solution" was because I've been following this thread since day one.
    3) skyking and his master mechanic friend had to unbolt the transmission from the cross-member and jack it up to even get the pipe in originally... in lieu of doing something like that, and keeping everything loose, as I knew to do, neither I nor the qualified mechanic doing my exhaust, could get the driver side flange to line up, without some kind of trimming. As I said it really wasn't a big deal, because it was the small peice of pipe that went into the larger peice... Trimmed it, and everything was gravey, bolted up the two flanges just fine. Only problem was now the y-pipe when lifted off the cross-member (and at a level angle) was at a height where the flange peice was hitting the middle cross-member. Even skyking had issues after loosing everything if I remember correctly, think he said they had to use a crow bar or pry bar to force the pipe up off the cross-member while tightening everything, after the fact.
  7. Mar 4, 2017 at 9:48 AM
    #67
    skyking3
    Tom
    Yes, it will work fine with the stock exhaust. My TRD Pro cat back has the exact same connection as the stock exhaust.
  8. Mar 4, 2017 at 10:49 AM
    #68
    Joe23
    from the sounds of it this is not something that can just be installed easily in your driveway
  9. Mar 4, 2017 at 10:53 AM
    #69
    Swiftks
    Spring, TX
    2016 TRD OR
    No, wouldn't recommend it. It's a thousand times easier to see what you're doing when it up on a rack and you can stand up and look.
    Laying on your back and trying to do this.... Hell to the no.
  10. Mar 4, 2017 at 11:05 AM
    #70
    austinklindsey
    Austin
    2016 4Runner SR5
    Toyo AT, Rola Rack
    Would you guys say it adds noticeable power? I really wish someone could get us a IS350 tune but until then lol...
  11. Mar 4, 2017 at 3:19 PM
    #71
    skyking3
    Tom
    Yes
  12. Mar 4, 2017 at 6:59 PM
    #72
    cch2
    cch2 Active Member
    2016 MGM Tacoma TRD OR 4X4
    Fold A Cover
    Does this effect the low end torque at all? Curious as how this interacts with the 3.5 and still waiting on the power extractors they are working on. Haven't seen a recent update on those. Basically I'm holding out for the aftermarket to increase as well as other people's experiences.
  13. Mar 4, 2017 at 7:37 PM
    #73
    Swiftks
    Spring, TX
    2016 TRD OR
    Just ordered the Vibrant Ultra Quite resonator. Will be replacing the bottle/performance resonator I put on... It's just to loud in the cab at 3k - 4k RPM. Even with a resonator added it's loud. Don't know if it's the y-pipe, 3" Magnaflow or the combination, but man it's got a grumble to it. Use to not bother me as much, and if I was in highschool still, I'm sure I'd be in love, but taste change I guess.... I don't want it to be stock quite, I didn't put all that crap on it to not hear and appreciate it, but damn...
    Anyway, ultra quiet resonator should help, I hope.
  14. Mar 4, 2017 at 8:46 PM
    #74
    skyking3
    Tom
    You may want to just add some sound deadening to quiet down the interior. It will also make your stereo sound better as well. This is what I am going to add soon after I finish the project I am currently on. The link is below.
    https://www.amazon.com/s/ref=nb_sb_...me&sprefix=dynamat,aps,177&crid=3SGXQKN2ZBWRU
  15. Mar 6, 2017 at 7:19 AM
    #75
    austinklindsey
    Austin
    2016 4Runner SR5
    Toyo AT, Rola Rack
    I meant to ask earlier but did it make your truck's throw a CEL?
  16. Mar 6, 2017 at 7:27 AM
    #76
    Swiftks
    Spring, TX
    2016 TRD OR
    Nope. Truck reads the O2 sensors from the first set of bungs behind the first set of cats. The y-pipe also has O2 bungs built in to connect the second set of sensors... Not sure what they're even there for, but no codes thrown.
  17. Mar 6, 2017 at 9:51 AM
    #77
    austinklindsey
    Austin
    2016 4Runner SR5
    Toyo AT, Rola Rack
    OK awesome, thank you for all the info
  18. Mar 6, 2017 at 3:01 PM
    #78
    Swiftks
    Spring, TX
    2016 TRD OR
    Noise problem solved. Swapped out to the Vibrant Ultra Quite resonator this afternoon... I'd say it cut the sound level by 40%. Really made the 3k - 4k RPM much nicer to listen to, without quieting the lower RPM (1k - 2k) to much. Just what I was looking for.
    Here's a quick video clip I did on the way home from the gym:
    https://youtu.be/bnwGg2bp5f8
    Here's a video I did of a cold start.
    https://youtu.be/kYWFoIdDSjI
    Sorry, had to use my cell phone. Best to listen to the videos in the truck via bluetooth, of with ear buds. Hard to get the bass/deep tones on crappy computer speakers or phone.
  19. May 18, 2017 at 4:27 PM
    #79
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    So, does this pipe still have issues with skids?
  20. May 19, 2017 at 12:24 AM
    #80
    Nexusix
    Nexusix Well-Known Member
    2017 Toyota Tacoma TRD Offroad 4x4
    Would the Y Pipe be legal in CA? I really want this.
