Urgent! LCA won't swing down!
Discussion in 'Suspension' started by thinkingman, Dec 28, 2012.
  1. Dec 28, 2012 at 7:00 AM
    thinkingman
    thinkingman [OP] Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    I tried using the video method of releasing the front springs using a jack, and after loosening the LCA bolts near the alignment cams, the LCA still wouldn't swing down.
    What did I miss?
    Any help appreciated!
  2. Dec 28, 2012 at 7:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    the bushings hold them in pretty tight. You may have to use a little bit of force.
  3. Dec 28, 2012 at 7:19 AM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    You might have to loosen the bolts that hold the lower arms, making sure to mark where you alignment cams are so you can get them back in the same spot.
  4. Dec 28, 2012 at 7:24 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    The alignment cams may be seized in the LCAs. Common problem as they're not lubricated from the factory.
  5. Dec 28, 2012 at 7:30 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Time to get the big muscles out. Use some type of white lithium spray grease to help break the bushings free. Big pry bar to pull or push that thing around.
  6. Dec 28, 2012 at 10:10 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This is my bet
  7. Dec 28, 2012 at 11:02 AM
    thinkingman
    redmond WA
    I loosened, sprayed, pried, and prayed and nothing.
    Something must be siezed with the cams....can you pry behind the cams without damage?
    How much can you do there?
  8. Dec 28, 2012 at 11:03 AM
    OZ-T
    Peter North
    British Columbia
    The cam bolts seize to a metal sleeve inside the bushing
  9. Dec 28, 2012 at 11:14 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Try heat next and keep spraying them with penetrating lube. Obviously do not heat up the lube :D
    Some people are able to break them free some are not.
    This is a warranty item so if you still have yours get it fixed by them for free.
    If your not under warranty you will need to cut them out, replace the bushings, and replace the parts you cut.
    One day Ill do a write up I promise...OZ :D
  10. Dec 28, 2012 at 11:17 AM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Sledge hammer. Tried and tested.
  11. Dec 28, 2012 at 11:21 AM
    OZ-T
    Peter North
    British Columbia
    If you use brute force and your cams are seized just keep an eye on your alignment tabs to make sure you don't flatten them
  12. Dec 28, 2012 at 11:22 AM
    XXXX
    sKiP
    05 Prius
    OP for reference this is the front bolts from the LCA
    rear
    what seizes
    I have plenty of more pics. PM me if needed.
  13. Dec 28, 2012 at 12:06 PM
    thinkingman
    redmond WA
    Good stuff here!
    Thanks.
    I wonder if it will move at all....
    I will let you know.
  14. Dec 28, 2012 at 6:51 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I'm thinking I need to remove mine and lube them like that? My last alignment sucked because one of the cams were seized!
    What did you use on those bolts? and whats the best way to remove while not completly screwing up alignment?
