[URGENT ] Mass Air Flow Meter Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Focoma, Nov 17, 2020.
  1. Nov 17, 2020 at 12:43 PM
    Focoma
    Focoma [OP] Member
    2001 Silver TRD Off-Road
    I have a 2001 Toyota Tacoma Xtracab. Today, the car lost all power while in neutral. Popped the hood and noticed that the Mass Air Flow Meter had disconnected from the Air Filter Box (See Photos). I taped over it and sealed the gap and was able to get her to run - although my rpms were low when idle.
    It looks like the gasket/whatever adhesive was used to connect the two completely broke and I don't believe I need to do anything other than clean the old adhesive off and reseal it. Can anyone verify this? If not, what else needs to be done.
    All components are without damage/cracks.
    Thanks in advance.
  2. Nov 17, 2020 at 12:45 PM
    0xDEADBEEF
    0xDEADBEEF Trash Aficionado
    2000 reg cab 4x4 flatbed MT
    Kinda looks like the airbox is cracked and missing bits.
  3. Nov 17, 2020 at 12:49 PM
    Focoma
    Focoma [OP] Member
    Nashville
  4. Nov 17, 2020 at 12:49 PM
    Focoma
    Focoma [OP] Member
    Ahh, that'd make sense. are there supposed to be threads there that the MAF Meter threads into?
  5. Nov 17, 2020 at 12:50 PM
    0xDEADBEEF
    I dunno, I'd have to go look. What engine do you have?
  6. Nov 18, 2020 at 12:13 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    I see a big chunk of plastic missing from the airbox, so you should probably replace that. Maybe go to the junkyard and look at an airbox for comparison.
