USB/aux in center console
Discussion in '3rd Gen. Tacomas (2016-2023)' started by roth_nj, Jan 11, 2017.
  1. Jan 11, 2017 at 3:53 PM
    roth_nj
    roth_nj [OP] Well-Known Member
    2017 DCLB trd off-road bbp
    Has anyone run a USB or aux to the center console?
    I don't need power in there (already has the 12v), but want to be able to connect my iPod to the stereo and leave it in there
    I guess I'm in the shrinking minority now, but I still have my 160gb iPod classic, and I like to just leave it in the truck and connected. It'd be nice to have it in the center console to avoid wires everywhere....
    I assume it shouldnt be too hard cause there's already power rub there, so there should be a cableway. Not sure if the head unit has any more input spots? Or if you'd have to disconnect the ones on the dash and run extensions. I wouldn't bother in that senerio
  2. Jan 11, 2017 at 4:02 PM
    rrentrop
    rrentrop TVDvinyldecals.com Vendor
    Rich
    Orange County, CA
    2016 Tacoma 4x2 Limited MGM
    T-Rex Billet Grille, N-Fab Steps, Tailgate decals, Bed Lights, Power Tailgate Lock
    Lift the "rug" at the bottom of the center console cubby and you will see a couple of holes. I ran my Mobius dashcam power (USB) and AVITY-01 Lightning-HDMI cable through them. If you feed the cables down from the center console cubby they tuck up nicely along the center console to the dash without having to remove anything.
  3. Jan 11, 2017 at 4:23 PM
    jkcashin
    jkcashin Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
    I was thinking of running the USB and AUX to the glovebox to free up a switch location... I don't use it, so why not! Subscribing!
  4. Jan 11, 2017 at 4:27 PM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    I was thinking the same thing. I still use an iPod too and would like relocate the USB/AUX in the glove or console area.
    This eBay part I found could serve as a repeater if the USB harness isn't long enough.
    https://www.ebay.com/itm/201758383076
  5. Jan 11, 2017 at 5:28 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    if all you're using is the USB and not the aux just take it out, buy one of those USB extension cables, plug it in (add tape to keep it in) and tuck it behind the dash and run the wire to the centre console like you want.
    Did the same on my jetta just reverse sorta. I didn't want it in the centre console I wanted it in the glovebox so moved it to there.
    I'll probably do the same just to free up a switch spot
  6. Jan 11, 2017 at 7:07 PM
    jkcashin
    Jamie
    2017 TRD OR AC MT
    Not using the AUX right now, but I might use it in the future, so I don't want to disable it altogether. I think I may just move the connector, as is, to inside the glove box.
  7. Jan 11, 2017 at 7:22 PM
    Joe23
    look around enough you can likely find extensions for the 3.5mm jack too to run to the centre.
  8. Jan 12, 2017 at 10:22 AM
    trussdude
    trussdude Well-Known Member
    Peoria, AZ
    2016 TRD Off Road
    I put all my music on a tiny flash drive and just leave it plugged into the dash
    jkcashin and ExplorHer like this.
  9. Jan 12, 2017 at 1:17 PM
    jkcashin
    Jamie
    2017 TRD OR AC MT
    Yeah, my thoughts were to put the stock connector in the glove box.... so the glove box will have USB/AUX, and run an extension off the USB behind the connector to the console. The JBL head unit can support 2 USB devices at a time!
    Joe23[QUOTED] likes this.
  10. Jan 12, 2017 at 1:27 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
  11. Jan 12, 2017 at 1:42 PM
    hotrod 15
    hotrod 15 Well-Known Member
    Robert
    2017 Toyota Tacoma trd pro
  12. Jan 12, 2017 at 1:43 PM
    gpb
    Atlanta
    How's the OP's ipod audio get to the stereo USB connection using that? :D
    jkcashin likes this.
  13. Jan 12, 2017 at 1:47 PM
    hotrod 15
    Robert
    Maybe I misunderstand, what I do is run my iPod inside my console connected to the USB and every time I crank up my truck it automatically connects via Bluetooth
  14. Jan 12, 2017 at 2:29 PM
    gpb
    Atlanta
    Pretty sure the OP's 160GB ipod classic doesn't have bluetooth... :D
    Joe23, hotrod 15, justin330i and 2 others like this.
  15. Jan 12, 2017 at 2:37 PM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    Shout out to other iPod classic owners! I still use my 160GB model and my even older 80GB 5th gen iPod video too. It's permanently stationed in the truck under the USB port. Though I do take it out to sync it or for using it as an iPod, you know, with headphones as the battery is still in good shape.
    I wouldn't mind moving it to the glovebox, less visible items for people to steal. Not that an old iPod is really worth that much, haha. Center console is full of stuff and has a divider in it anyway but I do keep a 12V to USB plug in there for charging my phone, just not enough space for an iPod.
    In my Tundra it was plugged into the aux input (3.5mm) 24/7 other than to charge it once a week. It actually ran on battery power the whole time I'd be driving till I swapped the head unit for one with BT/USB. The darn thing goes for ages on a charge.
    On a sidenote to the OP. Does your classic (7th gen I assume?) work right with the Entune software? By that I mean if you go to an album and click a song does it actually play that song? Mine won't play the first song when I tap on it and instead picks another one off the album and the title displayed is wrong, but it I change the track then go back it's right. Drove me nuts on my Classic, but it works 100% with my 5th gen iPod. Thus why my Classic isn't in the truck.
    Hammer40 likes this.
  16. Jan 12, 2017 at 2:44 PM
    roth_nj
    Ha, no... It doesn't. Plus I don't think the audio quality over Bluetooth is the best
  17. Jan 12, 2017 at 2:44 PM
    roth_nj
    Is it just jbls that can support a second usb?
  18. Jan 12, 2017 at 2:46 PM
    roth_nj
    I haven't even hooked it up in the new truck yet. But on the second gen with entune, the only issue I has was with shuffle. It did the same kind of think where if I shuffle alled, the first song would show differently on the display and plat something random. But the next track would be correct, and if I went back to the first track, would play what the first song was supposed to be
  19. Jan 12, 2017 at 2:50 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    I did this at first, but 160 gig iPod has a lot more music than what the USB will hold.
    Have you checked the prices of the classic, I was going to get another a few weeks ago, not happen after I saw the prices.
    Yes my classic does that as well, when it works.
  20. Jan 12, 2017 at 2:51 PM
    justin330i
    justin330i Member
    2017 TRD Pro, Cement, 6-Spd
    That's what I do as well. One of those flashdrives that are only as big as your thumb nail so it doesn't stick out to far.
