USB Plug Dead
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trvlngnrs, Apr 3, 2016.
  1. Apr 3, 2016 at 3:22 PM
    Trvlngnrs
    Trvlngnrs [OP] Well-Known Member
    Does the USB plug have it's own fuse? Mine used to power things, now it's dead.
    Thanks,
    Trvlngnrs
  2. Apr 3, 2016 at 4:01 PM
    Jason79
    Jason79 Well-Known Member
    PA
    2014 TRD OR DBL Cab SB
    Don't know, but double check its not the cable that's at fault.
  3. Apr 3, 2016 at 9:04 PM
    Samuryan
    Samuryan Active Member
    NorCal
    2015 DCSB
    mine only works if you plug in then turn truck on, once removed can not plug back in without turning truck off....FWIW
