USB port no charge?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VangaSTL, Oct 24, 2016.
  1. Oct 24, 2016 at 6:22 AM
    VangaSTL
    VangaSTL [OP] Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I used the front USB port today (the one on the center console just below the climate controls) and to my surprise nothing happened. I was expecting it to begin charging my phone but it didn't do anything. I tried with Samsung S6 and Samsung Note 5. Anyone else have this issue? Is it normal? Is there something I'm missing?
  2. Oct 24, 2016 at 6:24 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm pretty sure that port is to load your own music off a memory stick.
  3. Oct 24, 2016 at 6:28 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Your phones require more amps than what is provided by the USB port.
    https://www.tacomaworld.com/threads/usb-not-charging.396542
  4. Oct 24, 2016 at 6:29 AM
    froejoe
    froejoe Well-Known Member
    Rochester NY
    2016 TRD Sport 4x4 Access Cab
    From what I've gathered from other threads, it doesn't support charging. Not enough juice apparently.
  5. Oct 24, 2016 at 6:29 AM
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Mine charges my iPhone 6s just fine, and pops it up on my Entune under the USB entry to play music from.
    linkgoesnowhere and Tacoma_Jake like this.
  6. Oct 24, 2016 at 6:29 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    It only takes 1.1 amps to charge the phone? Your saying the USB port doesn't have 1.1amps?
  7. Oct 24, 2016 at 6:31 AM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    The problem is the USB port is only USB2.0
  8. Oct 24, 2016 at 6:34 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    You can still have a usb2.0 port with enough amperage to charge a phone. I feel like if this is the case where there isn't enough amperage in the port to charge a phone, I'm going to be pretty disappointed with Toyota.
  9. Oct 24, 2016 at 6:42 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Irrelevant to the power delivery.
    I think it may be only delivering the 500ma base USB spec, which isn't enough to charge some/many phones. I've not measured it.
    Really a non-problem, $10 and you have dual 2.4A charging ports either at the outlet a couple inches to the right or at the outlet inside the center console. https://www.amazon.com/Aukey-CC-S1-4-8A-Dual-Charger/dp/B00M6QODH2
    ManBeast and DanielTaco like this.
  10. Oct 24, 2016 at 6:46 AM
    DanielTaco
    DanielTaco Well-Known Member
    Daniel
    Iceland
    2016 Tacoma DCSB TRD OR 3.5
    I have one of these, works great, charges much fast than the usb port.
  11. Oct 24, 2016 at 6:54 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    I have the LG g4 and it charges. But charges very slow.
  12. Oct 24, 2016 at 6:59 AM
    Tacoma_Jake
    Tacoma_Jake Well-Known Member
    2016 Tacoma TRD OR DCSB
    Same here, iPhone5S by the way.
  13. Oct 24, 2016 at 7:03 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it is not meant to charge the phone
    if it does, great.
    if not, functions as designed. it's for multimedia data connection not charging
  14. Oct 24, 2016 at 7:05 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Well honestly, that's dumb
    Spare Parts likes this.
  15. Oct 24, 2016 at 7:39 AM
    cheuer
    cheuer Well-Known Member
    Utah
    2016 DCSB TRD OR 4x4 Blazing Blue Pearl
    Leer 100XR, Mobtown Offroad Sliders
    I was all set to recommend a charge-only USB cable that I've had luck with charging from a couple made-for-iPhone car chargers, but I just ran out and tested it and it doesn't work at all. Seems like you might be right about the amperage. I think I've seen some posts on here about hooking that USB port up to a real charger, I'll see if I can find it.
    Edit: can't find the forum post, but I'm thinking it was one of these used to add a couple ports instead: https://www.amazon.com/CH4x4-Toyota-Small-Power-Socket/dp/B00TEICVHY
    VangaSTL[QUOTED][OP] likes this.
  16. Oct 24, 2016 at 9:12 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    to have an USB port and it not have enough juice to charge something is completely frigging stupid. What a waste!!!
    VangaSTL[OP] likes this.
  17. Oct 24, 2016 at 9:17 AM
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    2016 Barcelona Red Tacoma TRDOR
    See build thread
    Odd, mine does just fine. Works with my iphone6+ and my wife's Samsung.
    Tacoma_Jake and Spare Parts like this.
  18. Oct 24, 2016 at 10:14 AM
    viking15
    viking15 Well-Known Member
    Joe
    same here
    Tacoma_Jake likes this.
  19. Oct 24, 2016 at 12:05 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    It's an "input USB port"...!!
  20. Oct 24, 2016 at 1:55 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    thats dumb
