USB Power Consumption Error
Discussion in '2nd Gen. Tacomas (2005-2015)' started by outdoorsmile, May 8, 2013.
  1. May 8, 2013 at 11:02 AM
    outdoorsmile
    outdoorsmile [OP] New Member
    Hawaii
    2013 Tacoma Limited
    I'm getting a display message stating that the "Power Consumption of USB device too high. USB device will therefore be turned off." This repeats every 10 seconds and cannot be stopped. Also, nothing is plugged into the USB ports. Photo attached. Just Bluetooth connected. Fixes?
  2. May 8, 2013 at 11:59 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    check to make sure no dust or crap is in the usb port.
  3. May 8, 2013 at 9:06 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If nothing is plugged into the USB Port and you are getting this message either the power leads to the USB Port are shorting and drawing > 0.5 amperes or the Stereo just thinks that it is...
    Either way Dealer visit.
  4. May 8, 2013 at 9:09 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Yep.
    Take it to the dealer.
  5. May 8, 2013 at 9:11 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    i had that the first time i plugged into my 2013. Went away shortly after on its own.
    Samsung?
  6. May 9, 2013 at 10:38 AM
    outdoorsmile
    Hawaii
    2013 Tacoma Limited
    Thanks for the feedback. Time for a dealer visit. Aloha
  7. Sep 22, 2017 at 3:36 AM
    tacoTJ666
    tacoTJ666 superlame
    TJ
    masshole
    2013 DCLB sport lifted on 33’s
    has any found a resolution to this issue, brand new battery in my 13' and I'm getting the "power consumption of USB too high" message with nothing plugged in at all , with my battery that just went I didn't have this issue at all
  8. Sep 23, 2017 at 5:57 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I don't think the two things are related. Probably a radio or wiring issue. You could unplug the usb cable from the rear of the stereo and see if it still happens. If it does the stereo is the problem.
