Use of Iridium sparkplugs in 2012 Tac vs recommended plugs
Discussion in 'Performance and Tuning' started by jland, May 13, 2014.
  1. May 13, 2014 at 9:19 AM
    jland
    jland [OP] New Member
    SC Louisiana
    2015 trd offroad
    none yet
    Has anyone used longer life plugs in their Tacoma V-6 and have any problems resulted?
  2. May 24, 2014 at 9:48 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Yes and the truck runs much better, more power better MPG....... I will still change them after a few years...
  3. May 24, 2014 at 10:26 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    You might want to just take a look with the Iridiums, I'm at 9 years and 70K with no loss in performance/mpg.
  4. May 25, 2014 at 9:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    One bank has NGK, and the other has Denso, from the factory. Not sure which rating the NGK are, but I believe the Denso are IKH20's. When the S/C gets installed it comes with IKH22's. Some people go one step colder with IKH24's. I run IKH27's.
    www.urdusa.com has all of those available.
