Used 2007 OEM Prerunner Tacoma Lift Kit
Discussion in '4 Cylinder' started by Softballdad13, Feb 8, 2012.
  1. Feb 8, 2012 at 9:40 AM
    Softballdad13
    Softballdad13 [OP] Member
    Luis
    Hesperia CA
    07 Tacoma
    Im looking to purchase anyones tacoma prerunner oem lift kit. I have a stock 4 cylinder , and want my truck to look like the factory prerunner.
  2. Feb 8, 2012 at 9:45 AM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    I don't think such a thing exists. I'm assuming you have a 5 lug? The Prerunner is a 6 lug with a totally different suspension design. There are options for lifting a 5 lugger but I don't know much about them.
    Also to make it look like a Prerunner you will need fender flares and bigger wheels/tires. It's gonna be an expensive proposition.
  3. Feb 8, 2012 at 9:47 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Yeah I dont think you can just add 6 lug suspension to a 5 lug
  4. Feb 8, 2012 at 9:51 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I figure you have a 5 lug since you want a lift to get the stance of a pre-runner or 4x4.
    There are some, limited, options to lift it. The cheap route would be spacers and an add a leaf, or you could go with a mid-travel or long travel setup that would be more expensive, but give you a quality suspension and a great ride.
    As for the rest of the look you'd have to get some fender flares and drill holes to mount them. Or if you do go long-travel.. just get some glass and have a badass rig.
    This thread could probably help you: http://www.tacomaworld.com/forum/5-lug/138807-official-5-lug-suspension-setup-thread.html
  5. Feb 8, 2012 at 11:30 AM
    Softballdad13
    Luis
    Hesperia CA
    07 Tacoma
    Yeah i do have the 5 lug, but dont like the fender flares. But would just like to achieve the prerunner ride height
  6. Feb 8, 2012 at 11:31 AM
    Softballdad13
    Luis
    Hesperia CA
    07 Tacoma
    tacomalex thanks for the info bro, your rig is sweet....
  7. Feb 8, 2012 at 11:35 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    http://fatbobsgarage.com/i-7254253-toyota-tacoma-2wd-5-lug-suspension-lift-kit-2005-2011.html
    this is the cheapest one out there for 5 lug. i think ryanjboutin has just the front spacer for sale if you want to buy that.
    you dont need to get the shocks that come with it unless you want to. you can use the stock TRD Bilsteins from a TRD sport or offroad. this will get you close to a stock 4x4/prerunner if not the same height. hope this helps! check out the 5 lug suspension thread too in the 5 lug sections there are pretty much all the options in there.
  8. Feb 8, 2012 at 11:52 AM
    Softballdad13
    Luis
    Hesperia CA
    07 Tacoma
    Hey 113tac thanks for the info. The kit looks like what i need . Ill post some pics in a couple of weeks. I plan on doing the work in 2 weeks..
  9. Feb 8, 2012 at 11:53 AM
    113tac
    Stephen
    Northern Virginia
    no problem definitely post up pics when your done!
  10. Mar 9, 2012 at 1:44 PM
    Softballdad13
    Luis
    Hesperia CA
    07 Tacoma
    Hey 113 Tac, I just installed the kit i ordered from Fatbobsgarage it is a nice kit for the price. Thanks brother
  11. Mar 9, 2012 at 1:51 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    where r the obligitory pics?
