Used engine or new heads?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ozark_RegCab, Aug 29, 2024.
  1. Aug 29, 2024 at 7:24 AM
    Ozark_RegCab
    Ozark_RegCab [OP] Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I have a 5VZ with bad compression (see below) after my fan bracket bearing went bad and caused the engine to jump timing. I drove it with a bad misfire to the mechanic, and now after changing the timing belt and water pump, it won’t start due to low compression, according to the mechanic.
    People have been pushing me towards a junkyard engine, but I already have at least a grand into this one, and how do I know the used engine wouldn’t also need a new timing belt, not to mention bad seals, etc. My engine also has new OEM knock sensors and fairly new valve cover gaskets, although it did leak a bit from the rear main/oil pan etc.
    Do I source new heads, or just throw a used engine in there and hope for the best?
    Also, what could have caused a non interference 3.4 to lose compression like that? Warped heads maybe?
  2. Aug 29, 2024 at 7:36 AM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I got my new heads for $400 a piece online for my v6. If you’re price gauging.
    TacoSR523 likes this.
  3. Aug 29, 2024 at 7:41 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Yea I saw some for that price at CHI. I was almost suspicious at how cheap they were though.
  4. Aug 29, 2024 at 8:18 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Prices from February of this year.
    I went with Clear Water heads, CHI had no cores at the time.
    Junkyard/cheap used option not included.
    Probably add $1000+ for labor, more if you move to a bigger shop than the guy you're at.
    Ozark_RegCab[OP] likes this.
  5. Aug 29, 2024 at 9:15 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  6. Aug 29, 2024 at 9:21 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I will say be careful putting new heads on a high mileage engine, often times if you do that they will start burning oil.
    MadNachos and Steves104x4 like this.
  7. Aug 29, 2024 at 9:27 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Wouldn’t it be getting new valve stem seals though?
    I suppose a junkyard/JDM engine could just as easily burn oil as well..
  8. Aug 29, 2024 at 9:30 AM
    O'Silver_Taco
    MD
    Depends on block miles......and got to go inside the engine.
    IF its immaculate and no sludge......and hone is still good...
    all this you'd need borescope and maybe drop the pan.....see if it was taken care of.....or beat to death
    Black97v6MT and MadNachos like this.
  9. Aug 29, 2024 at 4:19 PM
    Darce
    Darce Well-Known Member
    2003 Tacoma
    I am in a similar boat. I called and spoke with a fellow at metricmotorsusa, nice guy. They sell JDM motors but they pull the pan and valve covers, do leak down and compression testing. He told me 6 month warranty on the block and head. $3600+500 shipping to me in VA. I have not found any other JDM sellers that do this so far but dang that's a lot of bread. His opinion was to avoid east coast JDM resellers because of the saltier conditions. Does anybody have a JDM/used supplier they have dealt with and recommend?
  10. Aug 29, 2024 at 4:45 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    A cheap bore scope would be a good investment here. One that can turn 90 and look up at the valves as well as the bore. If the cylinders still have good crosshatch I may go with just heads. But a used JDM engine is a great option, not sure of the market on those though.
  11. Aug 29, 2024 at 8:14 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Is the low compression being caused by
    Heads….failed leak down test
    Or
    Block…..failed compression test
    heads(if no catastrophic damage/cracks) can be RM’d buy reputable machine shop for $400-$750….depending on condition
  12. Aug 29, 2024 at 8:16 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Not sure, the mechanic just told me the compression was bad. I asked about leak down but I didn’t get a response.
  13. Aug 30, 2024 at 4:02 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    were those heads from Yota1 ?
  14. Aug 30, 2024 at 5:17 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Black97v6MT[QUOTED] likes this.
  15. Aug 31, 2024 at 1:21 PM
    AW11
    AW11 Well-Known Member
    Frank
    2002 Dbl Cab 4x4 3.4l
    From my experience JDM motors are almost always pretty low mileage. I would just buy an engine from a reputable supplier. The only JDM engines I wouldn’t bother with are rotary.
    MadNachos likes this.
  16. Aug 31, 2024 at 2:22 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    I'd be skeptical of it not starting from low compression. To not even run would be extremely bad compression. Also not sure how low compression relates to replacing the heads. Compression is a bottom end thing unless valves are messed up but idk how you could manage that.
    cruxofthebisquit and Black97v6MT like this.
  17. Aug 31, 2024 at 2:44 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Yea I’m gonna get a second opinion after the long weekend.
    It’s possible it overheated and warped the heads if the fan came off.
  18. Aug 31, 2024 at 2:46 PM
    tacoman2001$
    Unless it's really fubar I'd doubt it'd be soo bad it wouldn't run. My guess would be the timing is off. It had enough compression out of time to run so compression really doesn't make sense.
  19. Aug 31, 2024 at 2:56 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Yea, my only other thought was maybe I washed down the cylinders or rings when I limped it over there with the severe misfire, or maybe burnt a few valves from running so rich?
    The mechanic was also trying to tell me it was an interference engine if the belt jumped enough. I’m pretty positive the 3.4 is non interference though.
  20. Aug 31, 2024 at 3:54 PM
    tacoman2001$
    Washed rings will go away though if you let it sit. Burned valves I'd usually poor valve adjustment. The 3.4 is non interference UNLESS the head had been machined.
    I-Give-Up and TACOTU3 like this.
