Used OME Dakars
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hashc93, Dec 11, 2019.
  1. Dec 11, 2019 at 8:20 PM
    Hashc93
    Hashc93 [OP] Well-Known Member
    I found a good deal on some OME CS047R.
    Craigslist add states that they are off 2017. which leads me to believe these are the newer heavy duty ones?
    Anything to look at in particular with used leafs? Obvious cracks ect....
  2. Dec 11, 2019 at 8:28 PM
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
  3. Dec 11, 2019 at 8:35 PM
    Hashc93
    Hmm I'll have to ask and see if he bought them new. Sticker and paint shows that part number.
  4. Dec 11, 2019 at 9:01 PM
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    Where are you located? I'll have a newer EL096R set with about 5k miles on them for sale in Phoenix :thumbsup:
    Kolter45, Wixo and msfit like this.
  5. Dec 11, 2019 at 9:04 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Best case they work. Worst case they’re clapped out and sagging.
    unless it’s a hell of a deal, I’d pass.
  6. Dec 12, 2019 at 2:38 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Agree with going new unless you know the seller. Last thing you need is to to buy and install twice due to sagging springs.
  7. Dec 12, 2019 at 5:25 AM
    Hashc93
    Good points thanks guys! I think I will pass on this.
  8. Dec 12, 2019 at 9:19 AM
    96carboard
    96carboard Well-Known Member
    Probably a good choice. The question I'd be wondering about them is WHY were they being taken off?
  9. Dec 12, 2019 at 9:21 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Are they considered the medium duty or heavy duty?
  10. Dec 12, 2019 at 10:01 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Dakar springs are very high value. You get a lot for your money even buying new. This is something I wouldn't bother with on the used market.
  11. Dec 12, 2019 at 12:21 PM
    mikalcarbine
    Phoenix, AZ
    2015 AC TRD OR
    I bought the HD and pulled the 3rd leaf to make it MD. I wanted the flexibility to make it the HD pack if I bought a camper shell. As it sits it is a medium duty, the HD leaf has been sitting in my garage and has never been used
    Wixo[QUOTED] likes this.
  12. Dec 12, 2019 at 12:30 PM
    96carboard
    ^^^ That.
    The "HD" configuration is definitely excessive. You can carry 500+ pounds on an "MD" while looking from the vehicle's stance that its an empty load.
  13. Dec 12, 2019 at 2:11 PM
    Wixo
    Hank
    Tint, LED interior
    What price you asking for?
  14. Dec 12, 2019 at 2:14 PM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Yep CS047 is the old part number.
    It'd only be a good deal if they are low mileage, mine have 81k on them and they have settled quite a bit..... i have had an ARE Z series cap on the truck since mounted......and for the record they have never squeaked....
  15. Dec 12, 2019 at 2:19 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How close are you to the leaf springs? Can you do an inspection? Do they look rusty - used? I picked up a used set of 95R’s for $300 Almost no surface rust was told that they had 3000 miles on them. I’m totally happy with them.
    95R’s going in
  16. Dec 12, 2019 at 4:32 PM
    Hashc93
    I’m about 3 hours from them. The guy said he bought them new and only has 500miles on them.
    He’s asking less than 300. But I would need to get the hardware to mount them up.
  17. Dec 12, 2019 at 5:25 PM
    rnish
    Tacoma 2nd gen
    I replaced all hardware: poly bushings, new shackles, 2 degree shims, U-bolt flip, Timbren bumpstop, greaseable bolts and leaf springs
  18. Dec 12, 2019 at 5:29 PM
    bzzr2
    bzzr2 Well-Known Member
    If he has a recent receipt and they look to be in new condition as they should for the miles it might be worth it. But then again how much gas $$ will you burn driving to get them? That's gotta be two tanks at least.
    mikalcarbine likes this.
  19. Dec 12, 2019 at 8:35 PM
    Hashc93
    All good points but I'm headed that way to ski. The production date is August 2016 on the sticker.
    So I think ill probably pass
  20. Dec 13, 2019 at 11:48 AM
    Captainskidmark
    Northern Illinois
    If you buy em and need bushing set, i have a set of dobinsons polturethane bushings with greasable pivots... brand new, never mounted.... .never got around to it, probably won't as I am pushing the wife to give green light on t4r..if interested pm me
