Used shell mounting
Discussion in '1st Gen. Tacomas (1995-2004)' started by Narty, Oct 12, 2019.
  1. Oct 12, 2019 at 11:21 PM
    Narty
    Narty [OP] Well-Known Member
    Orange County
    1998 Black Tacoma ext cab 4x4 A/T
    OME nitrochargers, Dakars+AAL, JBA UCA 285/75/16 Nitto Ridge Grapplers on TRD baja "beadlocks" Flippac
    Tried looking it up, but only like two threads have been made and neither were pretty decisive. Was looking through the shell forums, but most are for the rail system for the other gens. For those that have a shell on their 1st gen did you guys prefer a certain type of clamps? from what those two threads these two were mentioned. I also plan on using weather strips on the rails to ensure it is water tight, but was also thinking of replacing the boot part of the cap that attaches to the cab. the shell has literally no name or ID that i can find, but i was thinking you could just run a weather strip around the already used boot and just make sure its pressed up against the cab? thanks in advance
    https://www.amazon.com/dp/B00K7HENO...&pd_rd_r=e2b0c9f5-5d6f-11e8-8526-89311637ad07
    or
    https://www.amazon.com/Tite-Lok-Tru...cap+clamps&qid=1570947255&s=automotive&sr=1-5
  2. Oct 13, 2019 at 8:25 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    My 17 year old cap came with alum. clamps similar to Tite-Loc-Tru but only uses 4 as the side windows hinge up and storage boxes are there and block addnl. clamps mid section. IDK about cab to shell boot, dont have one. I used Amazon cap weatherstrip, leaks only with high pressure spray so far.
  3. Oct 13, 2019 at 10:44 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I have a snug top on my Taco and I prefer the black snug top clamps. They're slim and keep the topper securely attached to the truck. I had to make some small adjustments to my over rail bed liner to use the clamps.
  4. Oct 13, 2019 at 11:08 AM
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    I have 4 of those Tite Lok camper clamps on my 20 year old Glass Tite truck shell and they work fine. Be sure that when you replace the truck shell back on that your weather stripping gaskets are glued to the bed rail firmly and that its aligned with your truck shell. Clamp down the shell to your bed rails.Then test it to see if it’s waterproof by spraying a garden hose on your truck shell and look for leaks.
    I don’t know if they still make those rubber boots that go from the truck’s rear sliding window into the truck shell’s sliding window. I’ve seen people improvise their own from different material. My truck shell windows are too small for me to slide into from the back of the truck, but I can open both the truck’s rear sliding window & the truck shell’s window to access the gear that I have stored at the front of the truck bed.
  5. Oct 13, 2019 at 12:09 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    https://mysnug.com/
  6. Oct 13, 2019 at 12:21 PM
    Black DOG Lila
    Virginia
    Thanks? I paid $6.99 for the foam tape,replacement 3rd brake/bed light $14 plus free shipping.
    Hamer95USA likes this.
  7. Oct 13, 2019 at 12:39 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Yea, some parts here are pricey but some are hard to find and a good deal. The guys that work at this shop are super cool!! I’ve been in there for parts only to have them installed for free.
