Used Tacoma w/ Unknown Suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Laughing Bandit, Feb 22, 2017.
  1. Feb 22, 2017 at 8:28 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Yep. Beware this is a full 3" lift, so it is stressful on the OEM upper ball joint. Typically for lifts above 2.5", an aftermarket upper control arm is used, both to alleviate the ball joint angle and to restore caster (restore steering on-center feel).
    The shock is only extended by 1/4" (which gives just 1/2" lift on its own), not enough to bypass the frame bumpstop. :)
  2. Feb 22, 2017 at 8:31 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Agreed. I said "closer". :thumbsup:
  3. Feb 22, 2017 at 8:33 PM
    KenLyns
    Belly of the Beast
    When you extend the factory shock by 1/4", it is about the same length as a Bilstein 5100 or Old Man Emu shock. ;)
  4. Feb 22, 2017 at 8:34 PM
    Laughing Bandit
    Laughing Bandit [OP] Member
    2012 Toyota Tacoma 6-spd T|X Pro
    None. Yet.... :-)
    Thank you all! TacomaWorld never ceases to amaze me. I've got much to learn.
  5. Feb 22, 2017 at 8:53 PM
    Justinlhc
    Actually the 5100 for the 2gen Tacoma is closer to 3/4" longer than the oem bilstein. I've got some pics with the measurements somewhere around here, but I believe I've posted them on here along with the measurements of an oem bilstein with a 1" spacer and where the shaft ends in comparison to the bump stop. :pccoffee:
  6. Feb 22, 2017 at 9:04 PM
    KenLyns
    Belly of the Beast
    ^OK, so @Laughing Bandit will be more likely to break his upper ball joint than the shock stem. :D
  7. Feb 23, 2017 at 7:41 AM
    Laughing Bandit
    None. Yet.... :-)
    Let's try not to do either of those... ;)
  8. Feb 23, 2017 at 8:34 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This is correct... TX Pro is not the TRD PRO / TRD BAJA .... TX Pro is some earrings on a TRD OR. (namely cat back exhaust, TRD Beadlocks). It has the same suspension stock as a TRD OR.
    OP, you have a coil spacer lift in the front on both sides, plus a 1/4in lean spacer on the driver. You also have a 1.5in single leaf AAL in the rear. All running on the stock shocks. FYI to everyone the TRD OR / TX PRO pre october 2013 manufacture date came with a 2+1 leaf pack.
    big_jarv likes this.
  9. Feb 23, 2017 at 8:39 AM
    Rod03
    Rod03 Well-Known Member
    14 DCSB OR 300k+ Miles DD
    22 T4R OR, 12 TX Pro, 21 Taco Skewp!, 02 Taco OR (All Sold)
    Mine is a TX Pro and came with the Off road suspension, fakelocks, cat back exhaust, and off course the stickers about (15 extra horsepower).
    TX Baja had all that plus the nice TRD Billies and Eibach springs.
  10. Feb 23, 2017 at 9:48 AM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    Did not know that. Thanks for clearing it up!
    Rod03[QUOTED] likes this.
  11. Feb 23, 2017 at 11:35 AM
    KenLyns
    Belly of the Beast
    And just to add to the confusion, TX Pro was marketed as Trail Teams in Canada :)
