Using 2 sets of Hellwig 550 EZ helpers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjg, Nov 13, 2012.
  1. Nov 13, 2012 at 9:06 PM
    rjg
    rjg [OP] Yes
    RJ
    PA
    2007 Regular Cab 4x4 5 Spd 2.7
    LCE header, AFE filter, Blinglight Fogs, URD Short Shifter, Delay wipers
    I read a while back on another forum of someone that used 2 sets of 550 helper springs. One set in the front of the axle and one set behind. Since I have one set, I thought this may help with sag when towing a trailer and hauling weight in the bed.
    Has anyone on here tried this? I am just looking at a cost savings. Thanks:)
  2. Nov 14, 2012 at 6:24 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  3. Nov 14, 2012 at 7:21 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I went with the Hellwig EZ 990 one piece helper springs. Had them on for two years now, and they work as advertised. Note that i didnt have any issues with sagging before i installed them
  4. Nov 14, 2012 at 11:10 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Is it noticeably stiffer after the install?
  5. Nov 14, 2012 at 3:08 PM
    rjg
    rjg [OP] Yes
    RJ
    PA
    Thanks. I have considered those. The truck with the 550's sags slightly with a 600 lb ATV in the bed. It is definitely better than without the helpers.
    Since I may try and do some light towing at the same time, I thought an additional set may help even more. Just being cheap, however sometimes doing that ends up costing more money..
  6. Nov 15, 2012 at 6:20 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    thats usualy my case. do it right the first time and that way you wont have to worry about it not being what you want.
  7. Nov 15, 2012 at 7:31 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I have a front and back set of the advance auto cheaper version of the helwig 550's and it works well. The front set helps with wheel hop/stuttering when braking or taking off from a stop. I don't have any info to back it up but I feel like having front and rear helpers balances the leaf spring better than just have 1 helper on it. Either way, it definitely helps improve the ride and handling and it cost a whole hell of a lot less than a new leaf pack.
    jkuniverse likes this.
  8. Apr 10, 2013 at 4:29 PM
    chetweewax
    chetweewax Well-Known Member
    NJ
    15 TRD Sport
    Homelink mirror (Adding soon) Came with truck: FUEL Rims, Mickey Thompsons, Vinyl Tonneau Cover, Remote Start, 20% front window tint
    Did you notice any difference in the stance after you put these on. I just bought a single set for my taco, really doing it because with the cap on the rear sits lower than the front, was hoping this would give me an inch up in the rear.
  9. Apr 10, 2013 at 5:21 PM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    It did raise it a bit, maybe an inch.
  10. Apr 10, 2013 at 5:27 PM
    LaTorre
    LaTorre Active Member
    Joe
    Philadelphia
    TRD Sport
    Aero Turbine Muffler
    I have the firestone air bags ride is great can't go wrong.
