Using rear locking differential?
Discussion in 'Off-Roading & Trails' started by Packman73, Sep 20, 2008.
  1. Sep 20, 2008 at 7:54 AM
    Packman73
    Packman73 [OP] ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I would like to go offroading tomorrow after I get a little target practice in but my truck didn't come with a manual and I don't know how to use the rear locking differential.
    Can someone explain the rules of engagement/disengagement and use to me? Thank you.
    BTW, I apologize for the twin thread...:eek:
  2. Sep 20, 2008 at 9:59 AM
    DFPTaco
    DFPTaco It's TACO time!
    Josh
    Las Vegas, NV
    19 DC SB TRD OFF ROAD
    little lift, wheels and tires, prinsu rack, TRD Pro grille, some lights, and some scratches.
    GO SLOW!!! The locking diff is for very low speeds. The lockers are made for EXTREME offroading. Things like rock crawling and silt sand type places. You generally don't need the lockers if you're an average person.
  3. Sep 20, 2008 at 10:04 AM
    Packman73
    2007 TRD Off Road
    It's a Prerunner, does it have to be in 2L or can it be in drive?
  4. Sep 20, 2008 at 10:06 AM
    DFPTaco
    Josh
    Las Vegas, NV
    It should be in low.
  5. Sep 20, 2008 at 10:12 AM
    Packman73
    2007 TRD Off Road
    Ok, so I would
    1. slow or stop
    2. Put it in 2L
    3. push the button and go? That's it?
    Thanks. :)
  6. Sep 20, 2008 at 10:14 AM
    DFPTaco
    Josh
    Las Vegas, NV
    yeah... but seriously it's for low speeds. Check out your owner's manual and it will tell you.
  7. Sep 20, 2008 at 10:14 AM
    Packman73
    2007 TRD Off Road
    I would but I don't have one.
  8. Sep 20, 2008 at 10:29 AM
    DFPTaco
    Josh
    Las Vegas, NV
    you should call toyota and see if they can get you one. Also wouldn't hurt to call them and ask them about the locker as well... They are expensive trucks so never a bad idea to have all the info.
  9. Sep 20, 2008 at 5:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can be in "D" if you want to.
    You can use the locker at higher speeds, its just listed for 5 mph for liability reasons as the majority of "Joe Public" hasnt driven with a locker before. Many people on TTORA regularly use the locker at speeds much higher than what is listed in the owners manual. Especially on a PreRunner.
    Packerfan, When you are off roading with it, dont worry about the speed. Its more important that you dont use it on the pavement. :)
  10. Sep 20, 2008 at 5:42 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    Very helpful info....Thanks
  11. Sep 20, 2008 at 6:17 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Wrong. You can use the locker going as fast as you want, but you should only engage it when stopped or going less than 5MPH.
    This is also wrong. You can use the locker in D, no need to be in a low gear.
  12. Sep 20, 2008 at 7:53 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    just be forewarned that the truck WILL behave differently with the rear end locked and should be driven with quite a bit of caution until you get the hang of it
  13. Sep 20, 2008 at 9:31 PM
    Packman73
    2007 TRD Off Road
    Much thanks for the info fellas!!!!!!!!!
