using space above the CD player
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CalgaryRider, May 26, 2011.
  1. May 26, 2011 at 10:58 PM
    CalgaryRider
    CalgaryRider [OP] Well-Known Member
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    2009 Tacoma SR5 Too many to list, but its a SR5 with a TRD Sport Heart
    So I was sick and tired of looking at all the wires running over my dash up to my Sirus and GPS, so I decided to cut into the cover above the CD player and use the space and re-route the wires.
    final product
    the cut out
    some of backing removed
    It is pretty simple, and I was able to re-route the wires. I removed one of the covers beside the Aux input, ran all the power wires, Aux and antenna wire through the new opening, behind the climate controls, up to the left of the CD player, and then out above the CD player.
    There is a lip above the CD slot where I put some 2 sided tape to hold the Sirus dock in place, and with the GPS wire run behind no more wires over the dash and a clean finish.
  2. May 26, 2011 at 11:10 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    What he said^ will make it look hella pro
  3. May 26, 2011 at 11:21 PM
    CalgaryRider
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    Thanks for the feedback.
    Honestly I don't even notice, it is pretty close to the side and its nice and flush.
    Its definitely something to add, I personally hate the look of rubber gasket around things. I may sand the whole cover down and paint it black and then it would blend in.
  4. May 26, 2011 at 11:23 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    whoa. i would have never thought of trimming that area.
  5. May 26, 2011 at 11:30 PM
    kwelhand
    kwelhand Well-Known Member
  6. May 27, 2011 at 7:08 AM
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    You should line the edges with some black rubber trim to take away the sharp edge of the plastic and any imperfections in the cut. Looks good though.
  7. May 27, 2011 at 7:15 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
  8. May 27, 2011 at 7:23 AM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    ACK! Maybe try something like this instead.
    XM reciever inside of the sunglass holder, flip down to change station.
    When sunglass holder is closed, out of sight and out of mind.
  9. May 27, 2011 at 7:52 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    It's been cut already ^^^ ... Looks good to me
  10. May 27, 2011 at 9:28 AM
    2blu4u
    2blu4u Human after all
    Northern Colorado
    07 Indigo Ink Sport
    TRD exhaust, Pro Comp leveling kit, MB wheels, Yoko Geolander tires, black Grillcraft grill, BHLM, Pop-n-Lock, Access bed cover, Katzkin leather with seat heaters, custom console cover, shorter black billet antenna, Street Performance Throttle Body Spacer, bed mat, and bed extender.
    Does the unit get hella hot in the summer? I know that is why I stopped storing my sunglasses up there since I am not a fan of hot (temp wise) sunglasses.
  11. May 27, 2011 at 9:40 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    damn. you got balls to be cutting that up. but hey, not bad. i do agree with whippersnapper however, a homemade type of gasket out of an old mudflap or something like that would help with the look in my opinion. but if you said youre happy with it, rock it like it is. very ingenuitive of you.
  12. May 27, 2011 at 9:54 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Looks good, I would sand it down and add a rubber gasket if you can find one that looks good to you.
  13. May 27, 2011 at 10:02 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Holy Hack!!
  14. May 27, 2011 at 10:04 AM
    kmok
    Kyle
    Columbus, Ohio
  15. May 27, 2011 at 10:18 AM
    Blackened Taco
    Tony
    Virginia
    Nah it's always been fine up there, never had an issue. That being said I never really check it since I rarely change stations.
  16. May 27, 2011 at 10:34 AM
    Blackened Taco
    Tony
    Virginia
    Understood, the sad part is you cannot buy just the faceplate, you have to buy a whole radio to make it look factory again. That is gonna cost $$$$$.
  17. May 27, 2011 at 10:44 AM
    CalgaryRider
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    gotta take the good with the bad I guess.
    Thanks for all the feedback. I am never planning on getting rid of the Tacoma, but if I were it would be after everything went in the truck (ie stereo) so I would need to buy a new surround anyways to go with the deck.
    I know I need to clean it up a bit, just need to figure out what is the best method. Most of the cuts are hidden behind the Sirus so its one of those out of sight out of mind things :)
    We all do things that we think would be the best for us, just thought I would give some people ideas and see what kind of conversation or other ideas it would start.
    I'm happy with it, + no more freaking wires that hang all over the dash.
  18. May 27, 2011 at 10:44 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I love my truck too much to do something like that.
  19. May 27, 2011 at 1:33 PM
    dan0
    dan0 Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
    i've seen radios on here from free to 1200 bucks
    most in the 25-50 buck range
  20. May 27, 2011 at 1:54 PM
    Largefarva
    Largefarva Well-Known Member
    Fox Lake, IL
    '08 Double Cab TRD Off Road 4x4
    I got tired of seeing the wires for my gps and Sirius being draped up the front of my dash too.
    What I did was installed a 3 outlet power port in my glove box and wired it to the fuse panel using an add-a-circuit. I then drilled a hole in the back of the cubby under the cigarette lighter and accessory power ports along with mounting my Sirius receiver there. The hole is directly behind the receiver so now there are no visible wires to my satellite radio. Then, I just routed the power cable to my gps up the passenger side in my dash and ran it along the bottom of my windshield (pushed it down a bit with a putty knife so you can't see it at all) to the center of my dash right below where my gps is located. All you see is a few inches of the power cable where it comes out from between the windshield and the front of the dash to my gps.
    Looks pretty clean and now I can use my cup holders again. :)
