Using your factory speakers as spacers
Discussion in 'Audio & Video' started by atvking, Feb 21, 2009.
  1. Feb 21, 2009 at 12:35 PM
    atvking [OP] Member
    May 14, 2008
    2008 Tacoma PreRunnsr SR5
    Chrome Nerf Bars,Aluminum Billet Grille, K&N Series 77 Cold Air Intake ,SR5 Black & Gray Seat Covers, Flow Master 70 Series Exhaust with Dual Exhaust
    FYI.. You can use your factory 6x9 speakers as spacers for your new 6 x 9 speakers. If you don't care about your front 6x9 factory speakers.( they are thin and cheap) Remove door panel. remove speaker bolts. Trim the paper speaker from the plastic speaker body. Trim up the plastic speaker body so your new 6x9 speakers will fit inside. bolt up the plastic speaker body back on the door using the factory bolts. re-attach your speaker wires to the new speaker. carefully slide the new speaker into the plastic speaker body. Attach the speaker with long screws. Check to see everything works. Put your door panel back on. You just saved buying spacers !
  2. Feb 22, 2009 at 9:21 AM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Mar 6, 2007
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    Authorized Hybrid Audio Technologies Dealer (www.hybrid-audio.com) ARC Audio amplifiers, subs, processors now available! Helix Processors now available! For you super high end guys Brax amplifiers will be available soon! (PICS HERE and new website coming soon with Subwoofers, Amplifiers, Wiring Kits)
    That looks like a quick inexpensive way to do it however if you truly want to get the most out of your new speakers you need the properly made baffle/adapter. If you don't want to go to the expense of buying pre-made baffle/adapters you could get a small sheet of 3/4" MDF at Home Depot for 7 bucks and use a jig saw to cut them out. :)
