V-8 Tacoma - Would You?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by harshest, Dec 29, 2008.
Would you get the 4.7 if it was avaiable?
  1. Yes
    1,665 vote(s)
    65.7%
  2. No
    868 vote(s)
    34.3%
  1. Dec 29, 2008 at 11:02 AM
    harshest
    harshest [OP] I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    I was looking at the 4Runner on Toyota.com and noticed that it has a V8 option. So it got me thinking, if the 4.7 was available for the Taco would you get it?
    I think I would. I once had a 1995 Dakota with the 318 and that thing was a rocket. Although looking at the output rating the 4.7 only has 24 more hp but has 40 ft/lb of torque.
    Remember a good rule of thumb - There is no replacement for displacement.
  2. Dec 29, 2008 at 11:04 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Probably not. There isn't a significant enough power advantage in the 4.7 to entice me, especially considering the Camry has more HP. 0-60 in about 7 seconds is pretty good for a truck the size of the Tacoma, IMO, and if you want to tow a lot you should probably go for the Tundra.
  3. Dec 29, 2008 at 11:09 AM
    Joe B
    Joe B Well-Known Member
    Go supercharger over a 4.7L.It makes the V6 very quick.
    30 lbs more torque and 44 more HP than the 4.7L.
  4. Dec 29, 2008 at 11:12 AM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    no, i personally wouldnt want a v8 unless i had a full size truck, my v6 is more than enough...although it definitely would be fast
  5. Dec 29, 2008 at 11:27 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    1 cylinder is all I need the way I drive. If I had a V8, I'd just pull the spark plugs out of 7 cylinders and putz around like that.
  6. Dec 29, 2008 at 11:29 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    how many clutches have you gone through?
  7. Dec 29, 2008 at 11:32 AM
    klown
    Lynchburg, VA
    Clutch replacement is part of my routine maintenance. Every 5k miles I change the oil, rotate tires, swap out the clutch and rebuild the tranny.
  8. Dec 29, 2008 at 11:38 AM
    harshest
    Michigan
    05 PreRunner SR5
    I think at least it should be an option for the X-Runner since that is supposed to be the "street" version of the truck.
  9. Dec 29, 2008 at 11:43 AM
    BlueXenon
    BlueXenon Well-Known Member
    Los Angeles and Newport Coast
    2009 Magnetic gray TRD sport (SOLD) 2004 Radiant Red TRD Off Road (SOLD)
    Pro Comp 6" Stage 2 lift, N-Fab nerf bars, tinted windows, debadged, 6000k xenon headlights, 18" ProComp 7089 Wheels in black with BFG AT KO 33's, SnugLid tonneau cover, Line X'ed TRD skid plate. SOLD! Waiting for the 3rd Gen!
    I would. Only if its the 4.7 V8 not the 5.7 thats in the new Tundra's. The gas milage isnt that much different than our V6. I dont care about the speed or acceleration, but it would be nice to have to be able to get better towing.
  10. Dec 29, 2008 at 11:49 AM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    yeah if they made it for the reg cab. HELL YEAH i would get a V8
  11. Dec 29, 2008 at 11:58 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    Its not all about Horsepower......Look at the difference in torque. Towing would be much easier and also there would be more of an advantage offroading.
    even though i have a 2.7. thumbs up for a V-8........and if they do it please make it available in the regular cab.
  12. Dec 29, 2008 at 12:01 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    You're talking about 40 ft lbs. Not an impressive increase at all when you're talking about a V6 vs a V8. And, you know that Toyota would charge a premium to put that V8 in the Tacoma. Would the extra money be worth 24hp and 40ftlbs? I guess it depends on what that amount of money would be.
  13. Dec 29, 2008 at 12:05 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    yeah, it would probably be cheaper to supercharge the v6 than to get the v8.
  14. Dec 29, 2008 at 12:11 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Yeah, I'd rather have a blown v6 vs a v8.
    Yeah, a v8 rumble sounds nice, but I like the whine of a blower a bit better :)
  15. Dec 29, 2008 at 12:31 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Only if it had a bigger towing capacity.
    With a bigger engine, requires beefier transmission, beefier axles, etc etc etc.
    If they slapped a 4.7L in the current tacoma with no other changes - the towing capacity wouldn't change much (if any) at all.
    So, why bother?
  16. Dec 29, 2008 at 12:35 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^Yes, good points, all requiring money to do = a higher end price.
  17. Dec 29, 2008 at 12:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Actually, the 4.7 4 runner has the same auto tranny, and rear diff that the 4.0 Tacoma has. :)
  18. Dec 29, 2008 at 12:58 PM
    kbaum08
    kbaum08 Well-Known Member
    US of A
    09 trd off road dbl cab 4x4 barcelona red
    Jason Topper, Bed Rug, Weather Tech floor liners, Garmin Nuvi 760, Scan Guage, Trd exhaust, AFE dry air filter, shrockworks rock sliders, heated seats Katzkin leather, 2+ inch OME lift shocks etc heavy duty, ARB front bumper, Warn winch, Pia lights, rocktek rear bumper, locking tailgate,
    My purpose in owning my Tacoma is to have an everyday vehicle that gets decent fuel mileage, is fun to drive and I can use as a truck. I believe that the V6 fits the bill for me. I currently own a GMC with the Duramax so towing while an issue, is not a big issue for me. I have owned a 4runner with the V8 and was not pleased with the mileage, but it was fun to drive.
  19. Dec 29, 2008 at 1:07 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    More low end torque? Sounds like a deal to me. That and I love the V8 Rumble. Specially with a CAI and an exhaust it would sound excellent.
  20. Dec 29, 2008 at 2:08 PM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    my tacoma is just as big as the old tundras..... so no:eek:
