V6 AC for I4 Reg Cab?
Discussion in '4 Cylinder' started by Pitt1552, Nov 2, 2009.
  1. Nov 2, 2009 at 5:41 PM
    Pitt1552
    Pitt1552 [OP] Well-Known Member
    PA
    2010 Regular Cab 4x4
    Hey all,
    contemplating trading my 09 access cab v6 m/t trd sport for a 2010 regular cab 4x4. any thoughts? reason for trading is to save some money month to month, also, the commute to work is gonna get longer so i figure the added gas mileage will be a plus. Also finding that i dont really use the rear area of the cab often, and dont really tow. Not taking much of a hit on the trade so it seems like a good idea to me, figured i'd see what yall thought.
    Thanks
    (feel free to chime in on color options)
  2. Nov 2, 2009 at 6:03 PM
    Flyinhigh
    Flyinhigh Well-Known Member
    GA
    2018 SR DCSB 4x4
    ill trade my single cab 4x4 with you
  3. Nov 2, 2009 at 6:14 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    You might be able to refinance longer terms for the 4.0.
    I like my reg cab and wouldnt trade it,but everyone likes the truck they bought lol. Your 0-60 is gonna be about 10 seconds and not 7 seconds...give or take.
    youll see about 24 mpg if your mindful, 26 mpg if you push the issue a bit, lower maintainance etc.
    See if they can get a used reg cab and save more, but they are tough to find from what I see here.
  4. Nov 2, 2009 at 6:16 PM
    Pitt1552
    PA
    open to offers, after havin a regular cab what are your thoughts?
  5. Nov 2, 2009 at 6:17 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Get the regular cab, then swap in the v6...or v8 :devil:
  6. Nov 2, 2009 at 6:20 PM
    Canuckoma
    Canuckoma Cunuckoma 98 - 425,000 Miles
    98 Tacoma 425,000 miles
    Delo 400 Syn, Plywood Box Sides
    Way less room for McDonalds Wrappers and empty Starbucks cups. When You factor in cleaning the truck 4 times a year instead of only twice with the extended cab I don't think it will be worthwhile. Plus fat chick will expect rides if you end up with a bench seat.
  7. Nov 2, 2009 at 6:21 PM
    jandrews
    '09 FourDubDee TRD OR
    Personally, I would never give up the 6...frankly, I think it should be the base engine, and toyota needs to offer the 4.6L V8 as the optional trim. But then, I'm not exactly thinking with my business head there.
    In any event, to advise you better OP, we need to know some financial information. What's the status of your loan on the current Taco? How much payment can you realistically make on a car(s) per month? Etc.
  8. Nov 2, 2009 at 6:22 PM
    Tacoyota
    08 4wd
    I have to pack cautiously for hunting/hiking trips, my previous truck was a crew cab 6.5' diesel silverado, it held everything.I'm ok with that.
    For a reg cab, its comfy, and has plenty of leg room, I'm only 5'11" It'll go back more than I can use.
    Always a parking spot fit wise or u-turn to get it.
    Can't really explain it, but I think its more fun than any other truck I had.
    One last thought, test drive it, go up a hill at 55 or so mph, it'll still accelerate, but that will tell you if you like the modest power, to me its strong for a 4 cylinder.
  9. Nov 2, 2009 at 6:25 PM
    Pitt1552
    PA
    Thanks for the reply, i tend to drive like an old man so i'm not to worried about the 0-60, though the 6 is fun to get on every so often. Figured I'd be doing more hauling w/ a trailer than i have been, as the bed as been more than up to the task (mulch n brick n such). very few used regular cabs in the area, going to test drive one at another dealer tomorrow to make sure it feels right(the trucks i've been looking at havent been the exact model i've been eyeing up, this other dealer has one). Drove the 4 banger access cab and it seemed peppy enough for me. i tend to do about 18-19 mpg city/hwy mix 20.5 all highway, so i'm hoping there will be a bit of a gain w/ the I4.
    Any other thoughts and opinions are much appreciated! Thanks again all.
  10. Nov 2, 2009 at 6:27 PM
    Canuckoma
    You could always go for one of those used japanese imports. Isuzu makes some miniture 4wd cab over diesels. You would get 50 MPG and still be able to haul stuff and go 4x4ing.
  11. Nov 2, 2009 at 6:33 PM
    Pitt1552
    PA
    Making the payments on the truck hasn't been a problem, but i figure if i'm able to save money long term it might not be a bad idea. if i refi the current truck i'll save quite a bit as the interest rate will be far lower than the inital rate toyota gave me(5.25 vs 8.5), but i also figure the truck is pushing 12000 miles and i dont know that ive really used much of any of the utility that the v6 provides, and as other have suggested, the back seat turns into a bit of a junk area. So if i can get into a new truck with and save a bit more$$ i figure why not consider it.
  12. Nov 2, 2009 at 6:35 PM
    Canuckoma
    Hey easy.... empty Starbucks cups are not junk, they can be made into a funnel in a pinch for adding oil to your friends fFord products in a pinch.
  13. Nov 2, 2009 at 6:38 PM
    Pitt1552
    PA
    haha, mine tend to be dunkin donuts or wawa cups, but yes they do work well as impromptu funnels.
  14. Nov 2, 2009 at 6:41 PM
    Tacoyota
    08 4wd
    Honestly though, I want to pay the reg cab off, then get a used suburban or so for bigger trips or towing dads trailer. Based on my usage both would do about 80-90% of the same stuff.The 2nd truck would be more recreation/rv like.I'd drive the Taco 6000 of the 8000 miles i drive a year still most likely.
  15. Nov 3, 2009 at 4:53 PM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    I had an '07 regular cab and now have an '09 access cab. Main reason for me getting the access was that I occasionally have to haul the kids to school and I needed the space. For just me going back and forth to work the regular cab was fine. I kinda like the look of the regular cab better as well.
  16. Nov 3, 2009 at 6:46 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    I bet if you really do the math factoring in the depreciation between the trades, that money would have bought you a lot of gas over what you thought would have been saved.
    If you want the other truck, then get it but do not bullshit yourself on money saved by going from a V6 to a 4 cylinder.
  17. Nov 3, 2009 at 9:14 PM
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    I really agree with this. This is the first 4 cylinder that I have driven that has some really good power. I was on the interstate doing 80 and the ride was smooth. The truck didnt feel tapped out. I am 6'1 and with the seat completely back I have to reach a bit for the wheel. This is the first truck I have ever owned and I am glad that it is a Toyota Reg cab. Ill drive this thing till it gives up.
  18. Nov 4, 2009 at 3:07 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    you can't carry fat chicks in the reg cab. they don't fit. REG CAB FTW! lol
  19. Nov 4, 2009 at 1:21 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    I had a 2009 AC 4cyl 4X4. I now have a 2010 AC V6 4X4 Auto. I have owned both, so I don't have to guess. I preferred the 4 cyl over the 6. It easily got 25 IMPG, whereas my V6 has averaged 20 IMPG. I laugh when some people suggest that the 4 and 6 are close mileage-wise, they are not. The 4 has plenty of power, I found it towed my #2700 folding camper effortlessly, and very effeciently at 70 mph. My opinion is you will be very happy with the 4. The only reason I have the 6 is the wife hates shifting. If it came with an auto, I'd have bought it. I'd say you may save 20% on your fuel bill. Around town, maybe more. Of the 2 trucks, I preferred the 4 overall....Good luck
  20. Nov 4, 2009 at 3:41 PM
    Tacoyota
    08 4wd
    with snow tires at 29 psi , 300 lb of gear , 230lb of me, snow and rain, winter methanol blend and 65-70 mph , my 4 cyl still got 21 mph, amazing, oh yea 3 mtn grades too. That beats my 97 Dakota I used to have that would get 10-13 on the same type of trip(noitwasntahemi) just a 5.2 .:D
