V6 Cold Start problems?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prsgeetarman, Dec 7, 2009.
  1. Dec 7, 2009 at 4:53 PM
    prsgeetarman
    prsgeetarman [OP] Active Member
    Arkansas
    4x4 TRD Off Road
    Front skid plate, chrome exhaust tip, bug shield, vent visors, bed mat, ACI access limited edition roll top tonneau cover.
    Has anyone experienced cold start problems with their 2nd generation Tacoma?
    Mt 2010 V6 when setting out in temperatures around 40 F hesitates starting before it finally starts. It's not a battery issues as it is cranking it just appears to not be getting fuel but then finally starts. It's worried me a couple of times but so far it's never failed to start. After I drive it several miles and the engine warms up it starts just fine.
    Funny thing my 2005 V6 Tacoma did the same thing the last winter I had it but I never took it in for service since I traded before this winter.
    Maybe it's my fuel? I typically use 87 octane.
  2. Dec 7, 2009 at 4:57 PM
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    I use 87 but I don't think thats a problem. I've had this happen once while I was getting ready to leave school. It was setting outside all day in 40-50* temps. Now that mention it, this could be the reason why.
  3. Dec 7, 2009 at 5:21 PM
    cfenn
    cfenn Well-Known Member
    San Antonio, Texas
    PreRunner
    TRD exhaust,TSB, 5100's on the front, 884 springs, Total Chaos UCA, 5100's on the rear, Wheelers HD rear springs , Nitto 285/70/17's on MB TKO 17x8.5's
    My 07 has been doing this lately kinda crazy... just did an oil change maybe that is the issue guess I will see
  4. Dec 7, 2009 at 5:24 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    As in the starter takes a few seconds to crank the engine over? Cause this is normal cold weather starting.
    Come up here and try your truck. It was -22ºF (-45ºF with windchill).
    My poor truck. Still started first try. Don't worry about it.
  5. Dec 7, 2009 at 5:33 PM
    prsgeetarman
    Arkansas
    4x4 TRD Off Road
    Well that is why I worried a bit about it as it really has not gotten cold yet. Now if it got as cold here as you are talking I would be worried. :cool:
  6. Dec 7, 2009 at 5:45 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Stick the key in the ignition and turn the key to the "run" position and wait a couple of seconds and then turn it farther to start and see if that helps. It has nothing to do with the octane rating of the fuel.
  7. Dec 7, 2009 at 5:51 PM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    Both my 08 and 09 did that a few times when new and it stopped once I got some miles on them
  8. Dec 7, 2009 at 6:35 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    Exactly!
    It's takes a second or two. I believe it's something to do with the fuel pump.
  9. Dec 7, 2009 at 6:49 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I haven't had any trouble in cold weather, but twice since I got my 09 in July she took a few seconds to start.
  10. Dec 7, 2009 at 6:49 PM
    prsgeetarman
    Arkansas
    4x4 TRD Off Road
    Good tip!
    On my 2005 Tacoma I suspected the fuel pump but as it does it on the new Tacoma as well I thought I must be the common factor. ha. But it happens most when I am leaving work after it being parked 8 hours or so and I am probably trying to make a quick departure. I'll try turning the key on to run for a second or two tomorrow and then starting as it should be kind of cold as well then.
    Thanks!
  11. Dec 7, 2009 at 6:51 PM
    closed31
    closed31 Active Member
    09 TRD DoubleCab Sport 4x4
    none
    I had a Dodge once, that's how they normally start!!
  12. Dec 7, 2009 at 6:52 PM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    was -30C or -22F this morning in Alberta.
    I was supposed to be getting a ride to work so didn't plug my truck in but at the last minute had to drive my truck to work.
    Started first time no problem. Only problems I had were:
    central locking didn't work
    clutch was sticking to the floor and the shift leaver was really heavy
    Will be plugging it in tonight just in case :)
  13. Dec 7, 2009 at 6:55 PM
    jma
    jma What, me worry?
    2009 DC V6 SR5
    Yes
    do you have a block heater?
  14. Dec 7, 2009 at 8:15 PM
    snyder
    snyder Active Member
    none, dont want to void the warranty
    Well if my truck is plugged in Ive started it in -50 F while living in Alaska.
  15. Dec 7, 2009 at 8:17 PM
    dunkhi
    dunkhi CSULB socal
    Craig Sirois
    Southern California. Fountain Valley
    09 Ivan Stewart
    Toytec Coilover kit. Bilstein's 5100. Alcoa Wheels. General Tires. Magnaflow Cat-back. BLHM. Yellow fogs. 13TW5 jl sub. Stewart Decals.
    i just changed my oil. it rained as was pretty cold today where i was. my truck kind of stuttered when it tried to start. for the fist time
  16. Dec 7, 2009 at 8:18 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    A contributing factor, though probably not the primary reason, could be winter blend gasoline.
    A Dodge starting at all is a big victory.
  17. Dec 7, 2009 at 9:25 PM
    tictoc
    tictoc Active Member
    HAWAII
    FABTECH
    fabtech 6 in,33 procomp x terrain/micky thompson 17" beadlocks,steering stabilizer kit,k&n 77 series intake with throttle body spacer,ravin exauhst
    no problems here in hawaii!
  18. Dec 7, 2009 at 9:29 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    They come standard on all Canadian vehicles.
  19. Dec 8, 2009 at 3:38 PM
    jma
    jma What, me worry?
    2009 DC V6 SR5
    Yes
    Sorry, was referring to original poster.
  20. Dec 8, 2009 at 3:43 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I don't have the block heater in mine. I'll be getting one and installing it myself. There was a great thread on this with wonderful installation pics somewhere
