V6-How much coolant needed for full change? Dealer said 2 gallons is enough
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bruce1271, Feb 22, 2010.
  1. Feb 22, 2010 at 10:37 AM
    bruce1271
    bruce1271 [OP] Well-Known Member
    Dealer said 8 quarts is more than enough. but capacity in manual says 9.6 quarts. Anyone have any idea how much it takes to re-fill after a drain and flush? dont want to get done and be low.
    Thanks
  2. Feb 22, 2010 at 10:47 AM
    bruce1271
    Ok, but I only bought 2 gallons. dont want to be at home 20 miles form dealer and realize i dont have enough. Maybe I should buy another gallon to be safe.
  3. Feb 22, 2010 at 10:48 AM
    bruce1271
    And, once I flush, how do I flush out the water from the system? Can I hook up my air compressor and blow it out of the engine block via a hose? Will that work?
  4. Feb 22, 2010 at 10:49 AM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Have you tried looking in the back of your manual? It should say the proper amount, and it would be a good idea to have a little extra.
  5. Feb 22, 2010 at 10:51 AM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    No, there should be a valve to open on the bottom of the radiator.
  6. Feb 22, 2010 at 10:53 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah if I were you I would be another gallon just to play it safe, that way you can top it off here and there if need be.;)
  7. Feb 22, 2010 at 11:53 AM
    bruce1271
    Yeah, i know about the valve on the radiator and engine block. But how do you get it all out without adding something to push it out. then how do you get what you used to push it out out. Ha!
