v6 manual 13-14 mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JimmyBuckets, Nov 2, 2011.
  1. Nov 3, 2011 at 11:47 AM
    JimmyBuckets
    JimmyBuckets [OP] Well-Known Member
    Access Cab 6 speed V-6 sr-5
    I'm now in NC I think its a 10/90 blend...but a lot more city than before...but even before we moved I was usually seeing mid 15s.
  2. Nov 3, 2011 at 2:40 PM
    DSMissed
    DSMissed Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    I am lucky if I see 15, I will see as low as 13 even when I think I'm driving nicely. 06 6 spd
  3. Nov 3, 2011 at 2:46 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    I get about 20-21 mpg, and that's in the summer with the a/c blasting. About 3/4 of my miles are on the highway.
  4. Nov 3, 2011 at 2:47 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    :brianr:
    :p
  5. Nov 3, 2011 at 2:47 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    It's all about your driving habits.
  6. Nov 3, 2011 at 3:06 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Im getting the same here, maybe the cold weather. Only getting about 14-15 mpg both city/hwy, have done a whole lot of driving lately, went throught 3 tanks of gas in a week :eek:. With gas prices in canada $1.35 or $5 gal. Things are getting tight. Just got a tune up, replaced spark plugs and serpentine belt and filled up premium gas and added stp injector cleaner, didnt make a huge difference. Have to get my brakes done and tires soon.
  7. Nov 4, 2011 at 8:17 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Right... I did new plugs (30,000 mile service), a bottle of Techron, my tires are good and filled with air (on the high side), and driving habit aware (no jackrabbit starts)... and still 15.5 mpg consistant with my typical daily driving (3/4 city, 1/4 highway). It is my weekend highway trips that brings my average up (on Fuelly.com) to 16.5 mpg. On the highway, it really jumps up to 18-19 mpg.
    I am pretty convinced it is the more accurate odometer with my newer tires... My old average daily of 16.5 was with the stock tires (and the speedometer read too fast). Now that the 32" tires put the speedometer right on, I 'lost' 1 mpg! :rolleyes:
  8. Nov 4, 2011 at 8:22 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    prerunner
  9. Nov 4, 2011 at 2:04 PM
    TACK
    Nevada
    Is the gas mileage really that much worse with a 4x4?
  10. Nov 4, 2011 at 2:15 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Thats a shame, manuals should not get that bad. On another note, I am getting around 22-24 with my 2.7 5 speed on the highway and 19-20 city. Truck is an SR5 Access Cab also.
  11. Nov 4, 2011 at 7:22 PM
    David K
    Sure, we are heavier and have more rolling resistance. You will see most of us under 20 mpg max. and the 2WD are almost always over 20 mpg max. some posting 26 or better.
    Also, a DC being heavier could get worse mileage than an AC or Reg. cab.
  12. Nov 4, 2011 at 9:35 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Cold weather certainly doesn't help. My tank avg dropped to 18.8 on the UG today, ick!
    Then again, most people don't have my patience, or planning skill I suppose. If I have any chance at all of dropping fuel flow without obstructing the normal flow of traffic I WILL do it. Drove the 'rolla today with a 1200 mile avg of 37.2 when I got in; an hour later, I had that to 37.7 mpg. Must just be the way I've learned to drive.
  13. Nov 4, 2011 at 9:38 PM
    ATriplett513
    ATriplett513 Well-Known Member
    Phoenix, AZ
    2011 Dbl Cb, 4x4, 4.0L, 6-speed
    I've got the same truck. I get 13.5-15 in the city. The only time I get good mileage is on the highway.
  14. Nov 4, 2011 at 9:43 PM
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    when mine was new it got about the same. With all the mods its gone from 16 new to broken in 18, mods 16 - pizza cutters 18.5 and that's corrected for tire size. So lay off the gas keep it under 2500 rpm, around 2000 if you can it will get better. also plugs, air cleaner, ect helps a lot.
  15. Nov 6, 2011 at 12:31 PM
    #35
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    TOYOTAS, TOYOTAS EVERYWHERE
    http://ecomodder.com/
    I highly recommend this site. There are Tacomas on here getting an average of 35mpg+ without any external mods, but instead just simple changes in driving habits. Perhaps the info on here could help push your 4x4 V6 into the 20's range.
    Personally, we're shooting for an average of 35mpg+ with our I4 and 25mpg+ with our V6.
    One example is the wider your rims, the worse the fuel mileage, so if you went from stock 7" to after market 9", prepare to see a drop in mpgs.
  16. Nov 6, 2011 at 9:11 PM
    #36
    David K
    By doing what... I will look at your link... but in a nutshell, please.
  17. Nov 6, 2011 at 9:21 PM
    #37
    tacoman007
    tacoman007 ignorance is bliss,
    Josh
    san diego
    07SR5ACCESSCABDEBAGED4X4
    alpine headunit,12'' rockford fosgate sub,ipod in g-box,drop in K&N, Marine decor,5100's front/rear,uniden pc68xl,radioshack PA speaker
    i get pretty much the same thing. sucks.
  18. Nov 6, 2011 at 9:29 PM
    #38
    Mr.Ed
    Wilbur's Barn
    35mpg that's BS! unless is falling out of the sky. Just one more time 35MPG wait santa is at the door & the playboy girls have to give me a bath so I will be back soon:rolleyes:
  19. Nov 7, 2011 at 10:58 AM
    #39
    2004TacomaSR5
    Jon
    Montana
    I wounldnt be so doubtful, some members with I4s on here have done a certain computer chip mod that brought them up into the 30mpg range for 4x4s, some of the 5 luggers were reaching 35-37mpg. If I find out more info on the chips and a good reliable source that proves that they boost the mileage up that much, I will be getting one installed on my 2.7 no questions asked.
  20. Nov 7, 2011 at 12:58 PM
    #40
    JimmyBuckets
    The thread is about 4x4 v6 manuals. Not I4 whatevers. 18.5 is the best I have seen and driving it like that I might as well have bought the I4 since it would be faster and still get better mpg.
