V6 Manual Transmission Fluid Change Thoughts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Purdue Pete, Feb 21, 2014.
  1. Feb 21, 2014 at 6:24 AM
    Purdue Pete
    Purdue Pete [OP] Well-Known Member
    Indiana
    07 TRD 4X4, V6, 6 spd.
    Removed Charcoal filter, K&N filter, and that's it until I can save a bit
    Hey guys,
    Was reading through my Haynes manual and the maintenance section and read a few things I've never done. Does anyone drain their transmission fluid and fill it back up? Thought you had to remove the transmission pan to get all of the fluid out but they said just to remove the fill plug and then the drain plug. Anyone do this? Was going to change the fluid in the clutch pedal as mine is shifting pretty rough when cold so thought maybe the fluid has begun to deteriorate, would be surprised if it has ever been changed.
  2. Feb 21, 2014 at 6:42 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    yup its pretty important synthetic will make it shift smoother, you should change every 30000 pan pullin is only for autos
  3. Feb 21, 2014 at 6:48 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    The manual transmission has a drain and fill plug, very easy to change. I changed mine out at 30k and it looked pretty good, as did the transfer case, but the front and rear diff looked nasty.
  4. Feb 21, 2014 at 7:20 AM
    Suffield Miller
    Suffield Miller If your not driving a Tacoma...WHY?
    Miller
    just outside The Notch
    SR5 V6, 6spd manual, 4WD, DBL Cab spruce mica
    Tow package, alloys...straight up Tacoma
    I am waiting for my '14 SR5 V6, 6speed, D.Cab, Spruce Mica Short with Tow...
    Anyone know if Toyota will consider the manual transmission drain & fill part of their reg maintenance?
  5. Feb 21, 2014 at 9:31 AM
    Purdue Pete
    Indiana
    Hey thanks guys. In my Automatic transmission 4Runner things just seemed to go down hill after the transmission fluid was replaced. But it was an ordeal I guess. I didn't do it. Tried to find the Redline MT90 but haven't been able to on websites of local parts stores. Going to go in and look after work today.
  6. Feb 21, 2014 at 9:34 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2015 TSS sport DC 4x4
  7. Feb 21, 2014 at 9:48 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    You mean the free maintenance plan? No, it will not be covered in that.
  8. Feb 21, 2014 at 10:11 AM
    Suffield Miller
    Miller
    LOL Thanks!
  9. Feb 21, 2014 at 2:21 PM
    Purdue Pete
    Indiana
    This is not the place but I am doing it anyway. I just bought Lucas Synthetic ASE 75W-90 Gear Oil. It says rated for API GL-4, API GL-5. That makes me really nervous. People on here say that they use it with good results. But I would some other opinions.
    The Haynes manual is alright, not great. But alright.
  10. Feb 21, 2014 at 2:51 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    My six speed would forever grind 4th gear with GL5 oil, and shifting in general was more difficult. Switching back to GL4 cured that. I know the manual says GL4 or GL5, but there's a reason most manual trannies don't use GL5:
    http://www.widman.biz/uploads/Transaxle_oil.pdf
  11. Feb 22, 2014 at 5:20 AM
    Purdue Pete
    Indiana
    I did give it a shot and everything seems fine. I don't understand how it could have both rating however. That doesn't make a lot of sense. Going to monitor it and see how it goes. Probably will call my local amsoil dealer and ask him to set me up with fluids all around. Dirt bike too. Then if everything is shifting fine until my next oil change I'll replace it.
  12. Feb 22, 2014 at 9:03 AM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Redline MT-90 hands down. Best stuff for 6spd manuals. Its what i use. Change it every 30-40k and your good. Very good mesh.
  13. Feb 22, 2014 at 9:07 AM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Got redline on order for diffs, tcase, &tranny. Eager to try it out
  14. Feb 22, 2014 at 9:13 AM
    reece13
    North Carolina
    Its great stuff. I ordered mine from summitracing and got a few extra qts for the future. They were the best on price that i could find. Good piece of mind too when using Redline. I havent tried it in my diffs though, im still just using Mobil 1. I may try the Redline in my diffs in the future aswell.
  15. Feb 22, 2014 at 9:29 AM
    CASTRATE
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Amazon had the best price at time of order. Plus free shipping. Unfortunately, no one local sells it
  16. Feb 22, 2014 at 12:14 PM
    iroh
    michigander
    tonneau
    Yeah it is kinda dumb. It's supposed to rate how much extreme pressure additives are in it. Way back when there was supposedly everything from GL1 to GL6, with each higher number meaning more capability of handling shearing motion and pressures between gears.
    Nowadays we just use GL4 and GL5; most everything else is obsolete. Technically GL5 does meet GL4 requirements for lubrication so it can have that on the bottle. Unfortunately it's usually too slippery in a manual transmission (works too well!) and the synchronizers which depend on friction to work just slip. It can let the gear grind during a shift or it locks you out of gear until you rev-match.
    Then there's the yellow metals of the synchros used in many transmissions that the GL5's additives bonds to, and with every shift a little more gets stripped off until many miles down the road the synchros don't work anymore.
