V6 or I4 in 2013 access cab 4 x 4?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jvswaim, May 29, 2013.
  1. May 29, 2013 at 1:33 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Get a 2004 I4 Access cab and thank me later :)
  2. May 29, 2013 at 1:39 PM
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    one thing though if you want the offroad in the double cab you get stuck with the shortbox. i went with the doublecab longbox trd sport then am planning to add in the ARB rear locker. just something to consider if you are going to be using the box. :cool:
  3. May 29, 2013 at 1:39 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you make it sound bad ?
    there is nothing wrong with brake modulated auto-lsd, it is superior
    to a mechanical lsd clutch system in many ways. the end result is
    the same, you aren't gonna have one tire spin and make ruts
    standard lube and no clutches to deal with for starters. it works great
  4. May 29, 2013 at 1:41 PM
    jvswaim
    jvswaim [OP] Well-Known Member
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    That's very compelling also - except that I don't do wrenches much anymore - LOL. But you are right, it makes sense. There is an I4 access cab 4WD at a dealer about 100 miles away in Kans, but with the SR5 it's $28K.
    Thanks for the input.
  5. May 29, 2013 at 1:44 PM
    jvswaim
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    Is there something about the 2004 that disappeared on 2005 on up?
  6. May 29, 2013 at 1:48 PM
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    Just the pretentious db first gen owners that have them.. ;)
  7. May 29, 2013 at 1:49 PM
    jvswaim
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    Right - but I don't haul much anymore, since my all horses died over 10 yrs ago. In fact that's why I like the DC over the access cab - smaller box, so good excuse not to haul stuff. :)
  8. May 29, 2013 at 1:49 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I don't think it's necessarily bad, but I don't think it's good either. Having brake-controlled limited slip on a vehicle that's open-open is fine for the base model 4wd but I'd take the older mechanical LSD over the brake induced version. I don't think the brake controlled limited slip setup works as well but you're right, there are pros and cons to each system.
  9. May 29, 2013 at 1:55 PM
    linzy77
    linzy77 Does not suffer fools lightly
    Linzy
    Dumbfukistan
    2013 Access V6 TRD Off Road
    28K? WAY Too Much. I bought my 13' V6 Access Manual TRD for 29,900. Figure 4-5k for the engine upgrade and $2,500 from SR5 to OR. They can do MUCH better than that.
    Arm yourself with as much information as possible. I looked at yr old used ones and was going to pay nearly the same price as a new one.
    Check this out for starters.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/238072-2013-pricing-what-did-you-pay.html
    My dealer haggled with me for 2 wks til I used this and had my original price in 2hrs. http://www.fightingchance.com/ <-- like 40 bucks but worth it IMO
  10. May 29, 2013 at 1:58 PM
    linzy77
    Linzy
    Dumbfukistan
    They changed body style and size pre 04 = 1st Gen. 05 and up = 2nd Gen
  11. May 29, 2013 at 1:59 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I was just messing with ya. I owned two second gens (05-13) and decided for my own taste that a first gen would be the better truck. I'm not a fan of all the new bells and whistles but I get that most people are.
    I wish they made a workmans package with no carpet, no satellite radio, etc :D
  12. May 29, 2013 at 2:04 PM
    jvswaim
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    Wouldn't you just sit there with ping-ponging rear spinning wheels - all the power going to one wheel and then the other?
  13. May 29, 2013 at 2:13 PM
    jvswaim
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    I'm with you on that - I wish Toyo would make a work truck like Chevy with manual windows etc, to which you could add 4 x 4 and whatever other individual options you want, instead of pkgs that give you fog lights and cruise control in addition to the rear locker you need.
  14. May 29, 2013 at 2:34 PM
    jvswaim
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    Does this approach work on an ordered truck or just inventory?
  15. May 29, 2013 at 2:46 PM
    #35
    linzy77
    Linzy
    Dumbfukistan
    Mine was ordered (sorta). From what they say you cant order one per se. The dealer can see what is coming off the line with the package you want. Mine was half built and told em I would wait (they didn't like that). It was super white and I told em to change the color. Happened with no problem except they then tried to say it was "custom" and tried to add money BAHAHA. I told them to stop using that terminology or I would walk. I told em not to mention financing or I would walk. Told em I would stay for an hour each time I came also. I probably could have got a better price if it was in stock.
    Know their tactics and don't give them the advantage. If that dealer doesn't want to work with you go to another. Get a quote on paper from each. Play them against each other. Don't be in a hurry to get it and be willing to drive (and walk out the door). Be armed with data and dont believe a word they say. You are not there to make friends :) . If the guy in city doesn't want to help you call the rural guy.
  16. Jul 15, 2013 at 8:17 AM
    #36
    Jimbos13
    Jimbos13 Well-Known Member
    James
    Rhode Island
    2011 2.7L SR5 4x4
    I have a 2011 Access Cab 2.7L 4x4 SR5. Absolutely love it. I tow a 17ft whaler easily (although not far). It has plenty of power, just step on the gas. You will see some higher RPM's when really trying to accelerate but the I-4 can handle it. Mine has 45,000 miles on it.
  17. Jul 15, 2013 at 8:32 AM
    #37
    rickc5
    rickc5 Well-Known Member
    Rick
    Whitewater, CO
    2021 Tacoma TRD Pro
    none
    My $.02. We had a '97 2.7L 4-cyl and only got 16-17 mpg. Plus it was a snail getting up to freeway speed. We now have a '06 V6 TRD Sport and get 17-19 mpg, and 21 mpg on the highway. I think some of the performance issues and the poor mileage might be due to our elevation--4700 ft.
  18. Jul 15, 2013 at 8:42 AM
    #38
    Jimbos13
    James
    Rhode Island
    2011 2.7L SR5 4x4
    I consistently get 21+ mpg in my 2011 2.7L. That is with 70% city and 30% highway. I think you gas mileage difference has to do with comparing a '97 to an '06.
  19. Jul 15, 2013 at 9:21 AM
    #39
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I had a 2006 2wd with the 2.7L.
    I thought I was going to save gas. My MPG was around 15-16.
    Traded it in for a 2012 4x4 v6. My MPG is around 15-16.
    So in the long run it is how you drive it.
    I am a lead foot and like the get up and go.
  20. Jul 16, 2013 at 10:08 AM
    #40
    jvswaim
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    If the 2.7 can do that, it will certainly do anything I need. I'm used to 25 mpg from the 2.4, and have to think the 2.7 with 5 speed would give better mileage than the 4.0 6 speed since I don't pull anything around and don't haul gravel. :)
    By the way, I worked at the Naval Underwater Weapons Center in Newport, RI, back when the Tall Ships came to Narragansett Bay.
