V6 springs on a 4cyl
Discussion in 'Suspension' started by 09TacomaPA, Feb 17, 2011.
  1. Feb 17, 2011 at 4:59 AM
    09TacomaPA
    09TacomaPA [OP] Well-Known Member
    Phoenixville, PA
    09 AC 4x4
    If I were to put the V6 front springs on my 4cyl, would they add any type of lift to the front?
  2. Feb 17, 2011 at 5:23 AM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    i think the best way to get lift up front is to get the 5100's and set them to whatever height youre going for
  3. Feb 17, 2011 at 5:38 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Hmm that's a good question.
  4. Feb 17, 2011 at 5:40 AM
    09TacomaPA
    Phoenixville, PA
    09 AC 4x4
    I am asking because I have a set of the TRD Bilstein shocks and springs off of a TRD OR and wanted to see if I should just use my stock springs or the TRD Sport springs when I install the shocks.
  5. Feb 17, 2011 at 8:42 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    You could try the sport springs, see if you get some lift. No idea if toyota uses different spring rates between the v6 and 4-banger.
  6. Feb 17, 2011 at 9:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    yes. You would get about an inch lift.
  7. Feb 17, 2011 at 10:30 AM
    09TacomaPA
    Phoenixville, PA
    09 AC 4x4
    Would I need an alignment if I installed the V6 springs?
  8. Feb 17, 2011 at 11:17 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Yes you would.
  9. Feb 17, 2011 at 11:37 AM
    09TacomaPA
    Phoenixville, PA
    09 AC 4x4
    Thanks for the info, just want to sure I do it right the first time.
