Vaccum leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by Justin723, Jul 10, 2009.
  1. Jul 10, 2009 at 10:57 PM
    Justin723
    Justin723 [OP] Dont judge me
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- Trail Gear Solid Axle Swap, ARB compressor, high pinion 4.88 with ARB locker, 4.88 TRD Locker in the rear. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, and Weather Tech floor mats.
    Ok so when ever i change my vents to deffrost and turn the air on it makes my truck idle higher, depending on the temperature of my truck it will severely change the idle. Any ideas or where i should start looking for a vaccum leak?
  2. Jul 11, 2009 at 6:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Idleing up when Defrost or AC is turned on is normal.
  3. Jul 11, 2009 at 8:45 AM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    It's never done that before. It started after i went wheeling a few weeks ago and my truck was idleing at 2000 RPMs, it finally stopped idleing like that after just driving it around for a while, it didnt pull any codes either thats why i suspected it as a vaccum leak. And my truck actually idles lower when i turn AC on.
  4. Jul 11, 2009 at 10:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    AH! Ok then. Im not sure where to start. Have you checked to make sure all your vacuum lines are connected?
  5. Jul 11, 2009 at 2:06 PM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Yeah i didnt see anything, i havent pulled my dash apart yet though, wasn't really sure if it would be back there. I have an 01 BTW idk if they changed anything in between years.
