Valve cover gasket replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96BlueTacos, Oct 23, 2020.
  1. Oct 23, 2020 at 2:08 PM
    96BlueTacos
    96BlueTacos [OP] トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    I’m going to be doing new valve cover gaskets soon.
    It’s so messy now it’s obnoxious. Eventually I think I need to do my oil pan gasket as well, but I can’t tell if it just crap from above or what.
    If anyone has tips ahead of time or knows of anything else that I should do on my 365xxx 3.4 that would be a good idea while I have everything open that would be appreciated
    Any gasket preferences or other items I should replace?
    GQ7227 likes this.
  2. Oct 23, 2020 at 3:47 PM
    petecarlson
    petecarlson Well-Known Member
    2002 4X4 DC TRD
    You might want to add a PVC valve and spark plugs to this list. The 11183-62010 Camshaft plugs (Half Moons) can be cleaned up easily enough so you don't really need them. The 11188-62010 Plugs need to be replaced IMHO since it has a rubber seal on it.
    11213-62020 Valve Cover Gasket $24.09 2 $48.18
    11193-70010 Spark Plug Tube Seal $2.66 6 $15.96
    17176-62040 Plenum Gasket $9.63 2 $19.26
    90210-05007 Engine Valve Cover Grommet $1.08 16 $17.28
    11188-62010 Plug $9.09 2 $18.18
    11183-62010 Engine Camshaft Plug $6.63 4 $26.52
    90480-18001 PCV Valve Grommet $4.28 1 $4.28
    00295-00103 Oil Pan Sealer $11.62 1 $11.62
    96BlueTacos[OP], GQ7227 and TnShooter like this.
  3. Oct 23, 2020 at 4:12 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  4. Oct 23, 2020 at 4:55 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    geez, :)this seem to be the hott topic Of The Day around here :)
    there is brine krap salted roads on the way here tomorrow to worry about :(
    96BlueTacos[OP] likes this.
  5. Oct 25, 2020 at 6:24 AM
    96BlueTacos
    Mikey
    I think they do the mag. Chloride here in CO from my understanding
    GQ7227[QUOTED] likes this.
