valve cover gasket????!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaforlife, Feb 18, 2011.
  1. Feb 18, 2011 at 11:51 AM
    tacomaforlife
    tacomaforlife [OP] Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    went to check the oil today only to find out that its low and i looked around the engine and saw that the valve cover gasket seems to be leaking oil at the back of the engine:mad: has anyone replaced there valve cover gasket before? looks like its gonna be a pain in my ass!
    o and im about to hit 180k
  2. Feb 18, 2011 at 12:16 PM
    tacomaforlife
    Robbie
    AIKEN, SC
  3. Feb 18, 2011 at 12:33 PM
    tacomaforlife
    Robbie
    AIKEN, SC
  4. Feb 18, 2011 at 1:31 PM
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    its not bad just takes a little bit to get done.
    If they are leaking that much you should def change them, mine as well put in new plugs too while your in there
  5. Feb 18, 2011 at 1:55 PM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
    More time consuming than anything. The wiring harness on the drivers side is a PITA!!! You might want to try wrapping your harness in electrical tape when before moving it. This should keep the plastic guides from crumbling and falling into your valve train.
  6. Feb 18, 2011 at 3:34 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I'm glad you posted this because I am having the same problem. My truck has around 212000 miles and I have noticed that it has started leaking oil from the valve covers. Hopefully it's not that big of a job. I may tear into it this weekend so I'll let you know how it goes!
  7. Feb 18, 2011 at 7:03 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    yea mine seems to be a slow leak and so far its just behind the engine that its leaking.
  8. Feb 18, 2011 at 8:01 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Let it leak as long as its not drippin when your parked, Just keep and eye on your oil levels and you should be fine
  9. Feb 19, 2011 at 11:50 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Leaky valve cover gaskets (around the sides and back) seems to be a common problem for V6's. Just keep a good eye on your oil level untill you can replace it.
  10. Feb 19, 2011 at 4:21 PM
    mackattack07
    mackattack07 Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    be careful with the intake gaskets there pretty pricy
  11. Mar 1, 2011 at 5:14 PM
    stucksucksnayota
    Barry
    Well i got my new steering bushings put in this weekend. I guess I'll tackle the valve cover gaskets this weekend. I can't believe these things were $40.
    Any helpful hints with putting these on?
