valve slash
Discussion in 'Performance and Tuning' started by joselito76, Nov 4, 2012.
  1. Nov 4, 2012 at 4:45 PM
    joselito76
    joselito76 [OP] Member
    jose
    san antonio
    2001 pre runner
    so I did a compression test today and I got 150,150,145,and 150 that looks a bit low, I belive by the repair manual the normal compression is between 180 and 160 if I remember clearly.My question is if a valve slash would be worth doing to get some of the compression back or I should just get a new head or a low millage used head. My other option is to strip the head take it to a m8chine shop get it back to spec and install everything my self use what ever can be use and replace what ever need to be replace. So what do you guys think.thanks in advance.
  2. Nov 6, 2012 at 8:23 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I say start with the cheapest option first. Then if you can adjust the valves. Do so, then check the compression again. I would also do a leak down test after that. If your restored your compression but the cylinders don't hold the compression, then it means your rings are worn out.
    That will all give you a better idea of what all needs to be done or not.
  3. Nov 6, 2012 at 9:09 PM
    joselito76
    jose
    san antonio
    2001 pre runner
    true,true. thanks torspd. One more thing how do you do a leak down test
    i just google it got it thanks
  4. Nov 7, 2012 at 6:31 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Pretty sure it's called valve LASH lol
  5. Nov 7, 2012 at 4:34 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    I would not worry to much. The balance between the cylinders is what is important. The actual number is a bit low, but it could be from gauge error. I have several compression testers in my shop and have seen a 25 psi variation between them when used back to back on the same engine.
    Did you prop the throttle valve open during the test?
    It will not hurt anything to check the valve lash. If it is out of spec then thing about doing the adjustment.
    G
