Vancity4x 1ton SAS
Discussion in '2nd Gen. Builds (2005-2015)' started by VanCity4x, Jul 6, 2013.
  1. Dec 31, 2013 at 2:26 PM
    #61
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    sweet, lemme know what he says, because I am just starting out to save up for the conversion and that would be nice to spend just that much less for the whole conversion
  2. Dec 31, 2013 at 4:37 PM
    #62
    VanCity4x
    VanCity4x [OP] Well-Known Member
    AB
    05 Tacoma
    3link on tons
    I believe with the inchworm adapter you still need the rear housing of the 4x4 a750f tranny, I may be wrong but that was my impression. The main shaft is longer in the 2wd tranny so the adapter would push the rear housing back further. That could effect the crossmember and where your shifter comes up. :notsure: The tranny was a pretty easy swap and keeps things simple.
    Get a copy of the factory service manual too, can download off afew sites. Lists all the parts, bolts, seals ect you'll need and torque specs.
    I'm going to get custom skids made up soon and going to get the crossmember remade, going to be beefier.
  3. Dec 31, 2013 at 4:40 PM
    #63
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    "The new Inchworm 5speed Auto PreRunner Adapter will allow you to bolt up a 4wd tailhousing to your 2wd 5speed automatic transmission."
    That sounds to me like you still need the rear housing from a 4x4 tranny, which is going to be damn hard to find without the whole transmission :rolleyes:
  4. Dec 31, 2013 at 4:48 PM
    #64
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Night run last weekend
    c16d219b62decb9c83508a42ad231ac1_zps1e51_036bb6604ba13d5d3c42d4258498661acb2fee10.jpg
    227be38f455540406da291f191ff2f0c_zpsc0ab_9997dec7d6e20df55980b4b1053d43f877d0cfef.jpg
    Added lights above the sliders, can see in the pics
  5. Dec 31, 2013 at 11:01 PM
    #65
    Alfuh
    2006 Prerunner
    I have a few mods
    well it was just a thought from what someone else found and posted, ive got no problem trying to find the entire tranny lol
  6. Jan 4, 2014 at 4:22 PM
    #66
    awsumdc
    awsumdc Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    I haven't seen the inchworm setup yet in person but if it were me doing this swap I would stick with the 4wd transmission and not mess with modifying my 2wd tranny. Just my two cents though.
  7. Jan 4, 2014 at 7:00 PM
    #67
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I have the inchworm adapter, it's about 2.5" thick so i'll be adjusting the front,rear driveshafts accordingly and also modify the trans crossmember.
    think i've almost sorted out the wiring to install a tacoma t-case into a 2wd, hoping to test the electrical system in the next few weeks when work slows down.
    I do wish I kept the 4wd trans from my donor though.
  8. Jan 4, 2014 at 7:19 PM
    #68
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    So you do need the 4x4 rear tranny housing tho with the inchworm Mike? Really interested to see how it goes with using the taco case and electronics.
  9. Jan 4, 2014 at 10:30 PM
    #69
    luka
    Kailua, HI
    yup, the rear trans housing is required for either method.
    following the electrical diagrams, it looks like the 2wd with e-locker either have the same 4wd ecu or a "mini-4wd ecu"
    the wires are identical for both systems, but the pin-outs are different and the 4wd have the ADD wiring and t-case bundle. looks like it also taps the signal from the ABS and vehicle speed sensor too, for the shifting conditions to be met.
    i'm rather excited to see if it works, but i'll still trade it out for the FJ case :p
  10. Jan 4, 2014 at 10:36 PM
    #70
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    definitely thinking about doing a 4wd conversion when i have the money. i just can't get rid of my truck especially with all the little things I've done on it lol.
  11. Jan 5, 2014 at 7:48 PM
    #71
    Alfuh
    2006 Prerunner
    I have a few mods
    im the same way man lol, just cant get rid of her, too attached lol.
  12. Jan 11, 2014 at 7:56 PM
    #72
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    This is the build where all the 2nd generation pre runner folk(myself included lol) go to drool.. :)
  13. Jan 11, 2014 at 8:30 PM
    #73
    TRDtexasTaco
    TRDtexasTaco Well-Known Member
    JP
    Sunnyvale Trailer Park
    06 TRD PreRunner
    Billy shocks, Maxtrac spindels, AllPro standard leafs, BAMF shock relocation, King 2.5 smoothies
    I saw this build..then i jizzed in my pants
  14. Jan 11, 2014 at 8:34 PM
    #74
    h.zack801
    h.zack801 Scumbag Extraordinaire
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
    I want to commend you on your efforts for the truck, I know she appreciates it. I get frustrated enough doing lift work and diff fluid change, I can't imagine how irritating this whole process would have been for me if I had done it. The truck looks great!
    And secondly, BC is somewhere I'd like to visit now, seeing this thread.
  15. Jan 12, 2014 at 1:43 PM
    #75
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Lol thanks guys. It was a lot of work and research.
    You should come up and check out BC. The mountains here are awesome. There's a ton of touristy things to do too. July and August are best months. Just be prepared for the cost, its not a cheap trip
  16. Jan 12, 2014 at 3:20 PM
    #76
    rickashay
    rickashay Well-Known Member
    Nice build man! Great to see more people from BC who get out and explore. I live in Alberta now but grew up/visit Nelson BC all the time. I did Whipsaw a few years ago and loved it (although it was entirely snow covered...). I'd love to come out West more and do some wheeling. If your ever interested in wheeling the Crowsnest Pass area let me know. Cheers
  17. Jan 12, 2014 at 9:49 PM
    #77
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Cool, there's actually quite a group of us in BC now, our BC Toyota 4wd Facebook page just hit 300 members after 8 months. Guna try and do whipsaw early this year in the snow and again in August. Was thinking bout headin over to Alberta at some point too, get group togeather, ill def hit you up for that.
  18. Jan 12, 2014 at 9:52 PM
    #78
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Installed engine hood light strip today
    1e13968943e71a0dfb059c1209bedaa8_zps2ba2_0406657f417b1765f9d40c4880424c8a09b71bac.jpg
    764423619d18dd4a6d06d5a7caf9bee8_zps4334_328ce22836cc428a66fb09e0f43a23c6ce93c608.jpg
    Also changed my cluster lights from 5000k to 4000k led's so there not as bright more of a soft white. Ill see how I like them might change back at some point.
    4000k
    22160fc37e8ff63c572f2a7dd960f36a_zps33fd_3ead4e8d9c9d529f4d1fc8b21a211d6c9c582800.jpg
    5000k
    568bcd86e8f58141d6d46f44d414b015_zpsd50d_cd5819be292e9475d9bf1e27f8140c9c78e02e93.jpg
  19. Jan 16, 2014 at 9:31 PM
    #79
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Put down a deposit today for one of these bad boys with 10w light bar and pods :cool:
    559955f470f627df611a08e4fd926e98_zpsac5c_775cd5cd185ba43513811694bb48c25d0228c7d8.jpg
  20. Jan 17, 2014 at 3:47 AM
    #80
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    ^^ Nice! That is exactly the route I would go too if I got another bumper. Love the hybrid design.
