Various taco questions...
Discussion in '1st Gen. Tacomas (1995-2004)' started by gilracer, Jan 27, 2009.
  1. Jan 27, 2009 at 4:56 PM
    gilracer
    gilracer [OP] El Terrible
    Pleasant Hill, Iowa
    02 Double Cab, SR5
    Hey guys need some help on a few things. I have had my 02 quad cab taco for a month now and I am only averaging about 14mpg. This is mostly highway driving! I have done the usual things, changed air filter, checked tire pressure, and changed oil. After I changed the oil to RP 5w 30 my average went up to 15mpg. Any ideas what is causing the bad gas mileage? Second, checked the oil tonight and I am already down one quart from my oil change two weeks ago. No leaks. This was the first time that I have run synthetic, so could that be the cause of this? Last, I have noticed that when in 4 wheel drive, if I reverse or drive forward slowly with my steering wheel at lock right or left, there seems to be some binding (truck doesnt want to move). Is this normal, I dont have a lift on my taco, or bigger wheels or tires. Any help appreciated, thanks guys....
  2. Jan 27, 2009 at 5:22 PM
    swsteven
    swsteven Well-Known Member
    houston tx
    2001 tacoma trd
    3 inch lift bilsteins and aal 16 inch pro comp wheels, m/t tires
    try changing ur diff fluid ,it might help on both ends
  3. Jan 27, 2009 at 5:24 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....try changing the diff fluids....maybe all to synthetic, as well as the transfer case. for a little better mileage.....clean the throttle body and change the fuel filter. also....seafoam the motor.........shou.d get some mileage back. how many miles you got on the tacoma?
  4. Jan 27, 2009 at 5:25 PM
    gilracer
    Pleasant Hill, Iowa
    02 Double Cab, SR5
    93000 miles on her
  5. Jan 27, 2009 at 5:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.....i'd say time to do what i mentioned.....you'll get some mileage back definitely. did you do the deck plate mod yet?? if not......do that too man......it'll really help.
  6. Jan 27, 2009 at 5:29 PM
    Argonne Tacoma
    Argonne Tacoma New Member
    Romeoville, IL
    09 Tacoma 4x4 Off Road
    I have an 09 Tacoma, I only get 18 mpg on highway. What do you guys get? Anything better?
  7. Jan 27, 2009 at 5:32 PM
    gilracer
    Pleasant Hill, Iowa
    02 Double Cab, SR5
    Havent done the deck plate mod yet, whats the mpg increase
  8. Jan 27, 2009 at 5:35 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you have the v6.....thats about right. switch over to synthetic oil, and switch the transfer case and diffs over to synthetic oil too.....and give the truck some break in time.....the mileage will definitely get better.
  9. Jan 27, 2009 at 5:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well......i cant tell you a definite, but im getting around 20 mpg now....on crappy winter blend gas..............and i have had up to 23 in the summer..................and i run full synthetic everything, have the deckplate and an exhaust....on my 04 double cab.
  10. Jan 27, 2009 at 5:40 PM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    my mpgs dropped a ton with the cold+ winter gas. I used to get around 15 in winter with the 4 runner that had the same engine. then it would shoot to 18 and 19 in summer.
  11. Jan 27, 2009 at 5:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah.....winter blend gas will kill fuel mileage for sure.
  12. Jan 27, 2009 at 5:46 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    X2 on seafoam... that stuff works wonders!!!
  13. Jan 27, 2009 at 6:28 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Seafoam is awesome... did it to my DD...
  14. Jan 27, 2009 at 6:32 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I seafoamed my engine a few weeks ago, and I was planning on seeing what mileage im getting now, but I got injured at work and havn't drove my baby in 3 weeks. I was getting about 15mpg. So if I hope the seafoam helped me out. If not I guess i'll try changing diffs, and Trans. case to synthetic.
