Vehicle Stability Control activates on dry hills after complete stop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Driver57, Nov 19, 2024.
  1. Nov 19, 2024 at 7:42 AM
    Driver57
    Driver57 [OP] New Member
    2020 Taco TRD Off Road
    Howdy everyone.
    This is my second post, having introduced myself over on the New Member thread.
    A month ago, I purchased a used 2020 TRD Off Road automatic with about 17K miles on it. The truck runs nicely and overall I'm very happy with it. One problem occurs however when I'm on a steepish dry uphill grade at a stop sign. I come to a complete stop and before I start to move forward, the VSC light comes on and I hear a not-so-pleasant clunk from what sounds like the rear end. This problem does not occur on moderately steep hills nor at any other time. The truck shifts and runs smoothly at all other times. I can avoid this from happening by a little fancy footwork of simultaneously pressing on the brake and then giving it a little throttle. By the way, at no time when this is happens is the truck drifting backward. Though some sensor somewhere may think it's about to.
    What is up with that? Is it something that's going to lead to worse things over time? Thanks A LOT for your help on this.
  2. Nov 19, 2024 at 7:58 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    That is how mine worked ... and it surprised me. I was trying to move up a short but very steep hill section. By using the brake first it kept the truck from sensing a "down slide" before trying to engage gears.
    When parking any vehicle on steep hills that can happen. If you put an automatic transmission into park THEN set the parking brake the transmission can "settle further" first and become difficult to shift out ... at least in past years. Parking on steep hills I generally set the parking brake first so the transmission will shift out of "park" easier.
    Chew and lastcall190 like this.
  3. Nov 19, 2024 at 8:01 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    My 5th gen AWD 4Runner does it. Certainly a quirk, albeit a normal one.
  4. Nov 19, 2024 at 8:37 AM
    Amocat15
    Amocat15 Well-Known Member
    Bucks County, PA
    2021 DCSB TRD OR
    Yep normal for the TRD's - it is "helping" you by activating the brakes so you don't slide backwards in the short time between letting off the brake pedal and pressing the go pedal enough that the transmission can start you moving forward. I agree it is unpleasant and surprising especially the first time it happens! But that is just how it works.
    Chew and musicisevil like this.
  5. Nov 19, 2024 at 8:48 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Normal. It’s called hill-start assist control
    RTFM
    Chew and jmneill like this.
  6. Nov 19, 2024 at 8:49 AM
    jmneill
    SE
  7. Nov 19, 2024 at 10:02 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    eurowner likes this.
  8. Nov 19, 2024 at 10:08 AM
    jmneill
    SE
    Negative.
  9. Nov 19, 2024 at 10:11 AM
    gudujarlson
    Minnesota
    I think you might have missed this part;
    “By the way, at no time when this is happens is the truck drifting backward”
  10. Nov 19, 2024 at 10:13 AM
    jmneill
    SE
    You're right, I did.
    Apologies..
    gudujarlson[QUOTED] likes this.
  11. Nov 19, 2024 at 1:51 PM
    Driver57
    Thanks everyone for your comments..
