vent stink after turning off a/c
Discussion in '1st Gen. Tacomas (1995-2004)' started by az40ss, Aug 15, 2008.
  1. Aug 15, 2008 at 7:24 AM
    az40ss
    az40ss [OP] Member
    chula vista
    05 double cab prerunner shortbed
    Each time after I turn off my a/c my truck cab STINKS!!! Is there an interior cab filter that can be replaced? or does anyone know what I may need to do to resolve this issue? thanks...
  2. Aug 15, 2008 at 8:06 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Not sure if your 1st gen has a cabin air filter, if it does replace it. But do turn off your recirculate button(or Max a/c) before you shut off the engine and send a blast of fresh air through the system, that moldly/mildew smell will lessen. If that does not help, get a can of nicely scented LYSOL that says it kills germs. Turn on the system on recirculate with blower on 3 or 4 and spray and close the door for several minutes with doors and windows closed. Would recommend that you not be in vehicle while doing this and don't spare the LYSOL. Do this several times over several days and you will breath better. I am very allergic to mold/mildew and this really does help.
    Sorry for the long winded post. Hey Hey it is my 100th post:bananadance:
  3. Aug 15, 2008 at 8:15 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    same problem here as well if i get home and turn off the truck before turning off the a/c. The best solution is just to turn off the a/c and let the blower run for a few seconds prior to turning the truck off.
    -Dan
  4. Aug 15, 2008 at 4:45 PM
    mudjunkie
    mudjunkie Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    i had this same issue i went to the auto store and purchased some stuff called ozium it worked great it literally eats the stink away i used one can over a period of three days and i have not had this problem since. its been about six months now.
  5. Aug 15, 2008 at 4:47 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    might want to check for dead animals. rats, cats etc. I had a dead squirll in my moms buick engine compartment several years ago. it smelled awful
    GQ7227 likes this.
  6. Aug 15, 2008 at 5:38 PM
    rick
    rick `
    cabin air filter is located behind the glovebox. remove the glovebox door to replace it.
    and that ozium stuff is great.
  7. Aug 15, 2008 at 5:42 PM
    rick
    rick `
    sorry. wrong generation
  8. Aug 15, 2008 at 5:42 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    There are no cabin filters in the 1st gens. Get something called Frigi-Fresh and spray that in the intake and follow the advice of the guys up above too.
  9. Aug 15, 2008 at 6:14 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Its mold & mildew in your system. I had the same problem. The dealer does a cleaning that will take care of it. They spray a chemical through your a/c system. I had this done over a year ago & I think it was $40. My vehicle is 3 yrs old & I have only needed to have this done once so far.
