Very Bumpy Ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cusas6, May 21, 2007.
  1. May 21, 2007 at 7:10 PM
    cusas6
    cusas6 [OP] Member
    I have a 4x2 Double Cab Prerunner with the Long Bed. when I'm cruisin around town the ride is alright. But when I get on the highway, unless the road is perfectly smooth, as in brand new pavement, my truck starts to really vibrate up and down. It gets so bad on some road it makes my girlfriend nauscous. I can't tell of the backend is jumping up and down or if it is in the front. Either way it is annoying. I thought maybe it was bacause theback end was too light, but I loaded all my tools in the back one day and hauled them over to where I was working and it didn't seem to make a huge difference.
    Are there any adjustments I can make, do I need better shocks or something.
    Any thoughts are appreciated.
    -Scott
  2. May 21, 2007 at 8:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    first thing to do is to check the air in your tires. if its too high.....you'll definitely have a bumpy ride.
  3. May 22, 2007 at 12:26 AM
    MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    what package do you have?, what year?, how many miles?, what kind of tires, air pressure and do they have flat spots in them?
  4. May 24, 2007 at 7:31 AM
    Dominant967
    Dominant967 Well-Known Member
    put a load in the bed it will ride alot better...
  5. May 24, 2007 at 4:35 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    i have the same problem i will have to check the air in the tires then
  6. May 25, 2007 at 4:28 PM
    Spyder327
    Spyder327 Well-Known Member
    Phoenix, AZ
    2005 X-Runner
    Aquamist 2D meth/water injection kit, URD Exhaust, DT Long Tube Headers, Hood Struts, and lots of other miscellaneous stuff...
    Checking the air in the tires should be the first thing to do.
    If they are correct and you still have the problem, you should take it to the toyota dealer for a tire balance. If you just purchased the truck than the balance will be covered under warranty. When they balance the tires, they should also check what the road force variation is...
    A lot of the time if brand new vehicles have this issue its due in part to high road force variation, if thats the case toyota should/will replace whichever ones have high road force.
  7. May 28, 2007 at 8:33 AM
    MTOYOTAOWNR
    MTOYOTAOWNR Active Member
    There is according to Identifix.com, a recall for improper mounting of tires.
    Does everyone know about it??
    New to the site, great job so far.
    Marc :cool:
